EVO Vs. STi Handling
Old Jul 7, 2007 | 01:25 PM
  #91
LDOGGYDIZZLE's Avatar
The evo did handle better, better feel, but had this nasty mid corner push which delayed getting on the gas. Add that to the nice down low tq of a suby motor, you can see why it was a tick off. Now its much better!
I wouldnt trade it for a any Subaru personally.
Old Jul 7, 2007 | 07:47 PM
  #92
supersupra's Avatar
What would you recommend for autocross?
Originally Posted by LDOGGYDIZZLE
Luda,
I kinda agree.
The fist step is to decide what you'll be doing with the car.
Fixing the geometry is a must IMHO. Its an EZ way of make the car work better.
But I don’t have any reason to replace the front diff. The rear diff maybe.
I did however, finally, get the Whiteline R/C kit on the car. At the same time, I decided to install a set of springs that were given to me for testing by Robispec. These are his (yet to be released) street/track springs. I figured the R/C kit really is a fix for lowered evos, to raise the r/c back above the ground, and we’d see more of a benefit on a lowered car.
The results are fantastic! Nice soft ride for daily driving and a turn chewing, apex eating trackday car. The R/C kit was obvious immediately. Less roll and mid corner push is almost eliminated. The car just shoots toward the apex, rotates on demand and puts the power down. This allows to get on the gas much earlier, therefore faster.
Keep in mind this is all with stock shocks, stock sway bars, no chassis stiffening and street tires. It would rotate on demand with plenty mid corner grip. Much better than stock, no comparision really.
IMHO “must haves” for any lowered/trackday/street evo:
Whiteline rear bumpsteer kit
Whiteline front R/C kit
AMS rear trailing arm bushings
And a good alighnment
Motul 600
PFC 97’s
Ams Brake Duct kit
Products can be found at:
http://www.amsperformance.com/store/...Path=22_55_291
The above with an addition with an AMS flash, TBE, etc. Is more than enough for 95% of evo owners to really push their limits on the track and learn how to really drive the track.
Modesty aside, there wasn’t a single car that passed or caught my Evo with the above mods.
But an addition of a AMS GT3076, cams, VSR, and intercooler would sure make it a lot faster! Then maybe some shocks, then aero….. O’geez.
Hope this info helps everyone to make a decision on what to do first and especially those on a budget.
Happy Motoring!!!
Old Jul 8, 2007 | 05:23 PM
  #93
The above parts are great for autocross too. Really anywhere youd like a better handling EVO. Even for those occasional on/off ramps.
Old Jul 9, 2007 | 08:10 AM
  #94
Kay@kacework.com's Avatar
So much great info being shared iin this thread. Always good to see.
Old Jul 9, 2007 | 03:09 PM
  #95
bboypuertoroc's Avatar
Veteran: Army
Seems to be a rarity on this forum.
Old Jul 10, 2007 | 09:06 AM
  #96
Im glad you guys are finding it useful!!!!!!!
Old Jul 10, 2007 | 09:16 AM
  #97
Skimafia's Avatar
I have spent way more time in an STi then an evo, so I dont really recall the evo's handling. Reading this info, I am curious to know if that 'mid corner push' you are referring to is coming from torque steer. Could that be the reason for the push?
Old Jul 12, 2007 | 05:33 AM
  #98
No.
Torque steer is when you have a car with front axles that are different in length. Think Dodge Omni Turbo. When boost hit, you had to turn the steering wheel almost a 1/4 turn to keep it going straight. Now thats torque steer!
The actual "reason" for the mid corner understeer has alot to do with the suspension geometry. Can be as little as OE alighnment Vs. track alighnment. The above products help the geometry.
Old Jul 12, 2007 | 12:21 PM
  #99
ajbreezay's Avatar
evo+1!!
-Aubrey
Old Sep 6, 2007 | 06:06 AM
  #100
fil78's Avatar
lots of info - thanks
how difficult is it to install the Whiteline front R/C kit on a EVO IX ?
does it require any special tools ?
Old Sep 6, 2007 | 11:07 AM
  #101
It requires removal and replacment of the tie rods and lower ball joints. Then you need to re-align the car. Nothing special and real EZ on a new car where everything just comes apart so easily.
DO IT!!!!!!!!
Old Sep 6, 2007 | 11:12 AM
  #102
Vostok 7's Avatar
My Evo handled better stock than my WRX or STi ever did even with Tein Flex coilovers and strut bars and other chassis stiffening. And now that my Evo is Robispec'd... Well...
Vostok 7
Old Sep 6, 2007 | 11:27 AM
  #103
CharlieGsanD's Avatar
it will require a hydraulic press, ball joint removal tool as well as an alignment
the ball joint in the lower control arm must be pressed out (press)
the tie rod end must be removed from the spindle (ball joint tool)
& you have to remove & replace the tie rod ends (alignment)
Old Sep 6, 2007 | 11:37 AM
  #104
TouringBubble's Avatar
Wow .. that install sounds like a chore. It's gotta be done though =) Is there really a need for a specific press or could one be fabricated with a C-clamp or something similar?
BTW, thanks for this thread. I've learned a lot from it and I'm taking your suggestions to help set up my car for auto-x.
Old Sep 6, 2007 | 01:48 PM
  #105
Zeus's Avatar
You need a "big" press I'd assume. I've got a 12 ton that should do it. I doubt you can get away with a small one.
