Does Mitsu offer anything like this for EVO hard shifting
Old Jun 10, 2003 | 10:14 PM
Daveyd's Avatar
Does Mitsu offer anything like this for EVO hard shifting "thumping" noise??
Whiteline KSB751 Diff Lock Kit
This kit is designed to lock the front of the rear differential support outriggers where they mount to the body. It will help to reduce rear end float particulary under hard acceleration. It will also remove drive train "thump" on hard gear changes while delivering more precise handling and chassis response for big power engines and competition work including drag, solo and track cars.
Fits 1994 and newer Impreza and WRX's.
KSB751 Polyurethance Diff Lock kit - $25
Old Jun 11, 2003 | 07:38 AM
Daveyd's Avatar
Bueller..........Bueller....
Old Jun 11, 2003 | 09:00 AM
erikgj's Avatar
ralliart and POWERFLEX offer every bushing on the car for a VII they should work on a VIII.
Old Jun 11, 2003 | 11:02 AM
Daveyd's Avatar
interesting....any links?
Old Jun 11, 2003 | 11:15 PM
erikgj's Avatar
At the bottom of this page is the powerflex listing. You would have to check with powerflex to see what they have for a VIII.
The complete Ralliart Group N bushing list for the Evo VII, the most current that I have. With UK pricing
RA Part No Description Price Qty
RA403282K1 Insulator, front strut(top mount)Hs90 £33.04 2
RA554817K1 Bushing, front lower arm,front,Hs70 £21.48 2
RA519675K1 Bushing, front lower arm, rear,Hs90 £79.29 2
RA554820K1 Bushing, front stabilizer,23mm,Hs90 £19.17 2
RA554369K1 Bushing, rear shock, upper(A)Hs90 £10.56 2
RA554370K1 Bushing, rear shock, upper(B)Hs90 £10.56 2
RA589880K1 Bushing, rear stabilizer, 21mm,Hs90 £19.17 2
RA856461K1 Bushing, rear upper arm(body/front)'90 £17.19 2
RA856464K1 Bushing, rear upper arm (body/rr.)'90 £11.90 2
RA244851K1 Bushing, rear lowerarm (shock)Hs90 £11.90 2
RA864730K1 Bushing, rear trailing arm(body)Hs90 £19.81 2
RA369384K1 Bushing, rear diff. support insulator,Hs90 £12.56 2
RA809334K1 Bushing, rear diff. support arm, Hs90 £10.56 2
RA171989K1 Insulator, engine & t/m mtg, Hs90 £21.81 2
RA197518K1 Insulator, engine roll(front) Hs90 £21.81 1
RA554855K1 Insulator, engine roll(rear) Hs80 £21.81 1
RA844835K1 Bushing shift control, Hs90 £5.29 4
RA266941K1 Bushing, radiator support,upprHs90 £7.94 2
RA605173K1 Bushing, radiator support lwr, Hs90 £11.56 2
RA809280K1 Pad, Rear Spring Upper £11.23 2
RA529551K1 Muffler hanger, B, Hs90 £14.87 2
RA651790K1 Muffler hanger, D, Hs90 £13.21 1
This is the Evo extreme package of group N bushings.
RA369384K1 Bushing, rear diff. support insulator, , Hs90
RA510407K1 Bushing, Steering Gear Box (Rubber Hardness =Hs80)
JBAutosports
Evo 'For Sale' Suspension / Brakes / Handling
99
Nov 18, 2012 05:08 PM
LOVEBOOOST
May 5, 2010 04:56 PM
20psiMR
15
Nov 20, 2007 01:10 PM
