ABS light coming on at 60mph
Old Apr 19, 2007 | 09:16 AM
clairelouise's Avatar
hello every one have had problems with abs on my evo 8 and am starting to get a bit mithed with it to say the least, the light was coming on once driving down the road and took it to mitsy and plugged it in , we changed one senser ourselves and found it still done it then we replaced the drive shaft as we found it had a tooth missing
now once you drive over 60 mph and brake the peddle polses back and the car is all over the place , ive changed the brake fluid and have used 5.1 dot could this be the cause, i have bled it a number of times thinking it might be air i would take it back to mitsy and plug it in again but the light doesn't always come on but the peddle is always the same over 60. this is now a new problem and any help or pointers in some direction would be welcomed with open arms!
Thanks
Old Apr 19, 2007 | 10:27 AM
BlackSport350's Avatar
If the pedal and ABS function under 60 is fine, then your fluid and air in the system are ruled out. Chances are that there is still a sensor issue with the ABS and for some reason it is only manifesting itself at speeds over 60.
Old Apr 19, 2007 | 10:39 AM
rcheung's Avatar
If it only happens over 60 I defeinately think its still a sensor issue.
Old Apr 19, 2007 | 10:40 AM
BLKLIST's Avatar
hhhmm, my wife's VIII a.b.s light would come on randomly, once we had new pads installed the light never came back for whatever reason.....
Old Apr 19, 2007 | 10:41 AM
vortech_g35's Avatar
Could be also you are low on brake fluid, or you need to bleed your lines again.
Old Apr 19, 2007 | 11:52 AM
sonicnofadz's Avatar
Test all the sensors with a multimeter, replace all of them if necessary. Also test central ABS module. Make sure that you bleed ALL lines before you start to assume anything.
David Buschur
Dec 26, 2018 10:40 AM
Jeff_Jeske
Dec 9, 2011 07:12 PM
Elweld
Apr 23, 2011 02:07 AM
gavi101
Jun 24, 2010 07:52 PM
c900t16
Dec 16, 2007 01:34 PM
