Check this EVO with pics
Old Apr 25, 2007 | 10:37 AM
augosta's Avatar
Can't believe that when I first purchased the evo I had no intention of touching a screw!
It only took a few weeks of itching until modification virus took over. An exhaust here & a gauge there surely was going to be enough
How I was wrong! This thing turned from stock to I don't know what
Ok here it is. After six months work with the help of many this is was I have:
Engine
3 inch exhst catbck (amuse titanium); down pipe + test pipe (hks)
k&n air filter & alloy divider plate
blow off valve (hks)
ecu (motec m800 plug & play); wide-band o2 (lambda) sensor; motec boost cont. solenoid + connect; 2 position switch ecu
radiator (koyo); radiator cooling plate (cusco); radiator cap cp9a, ct9a (sard); radiator pipe (samco); alum. radiator pipe shield (b. whls)
intercooler (hks type r); intercooler ducting
turbo kit (hks garret 30 37s)
external fuel pump + plumbing kit; performance inlet manifold; throttle body 80 mm; fuel rail (ams); 1000 cc injector set (hks); fuel regulator (sard)
spark plugs (hks)
cylinder head studs(arp)
oil catch can; modify oil system + large oil pan
2.3 stroker kit with requirements (aat)
cyl.head + block modification/honing
thermostat 71deg. C
engine dampener (sard)
tuning (motec) 2 maps
Handling & Drive-train
race suspension (zeal - function)
f+r stainless brake line kit (endless); frnt racing disc rtrs crss drld (endless); rear rotors basic (endless); racing pads (endless); brake duct cooling kit (ams)
twin carbon clutch (exedy)
limited slip dif. frnt type rs (cusco); limited slip dif. rear type rs (cusco)
bump steer correction kit (whiteline); front steering correc. Kit (whiteline); roll center adjust kit (whiteline)
rear triangle os-t (cusco); rear brace (cusco); front strut bar triangle bar (cusco)
anti-sway bar frnt 25mm (cusco); anti-sway bar rear 23mm (cusco); sway bar links frnt & rear (whiteline)
lower arm bar ver. 1 (cusco); lower arm bar ver. 2 (cusco)
vortex generator; front c. fiber spoiler lip (apr); gt3 c. fiber side mirrors (apr); gtc c. fiber wing (apr)
slick tires (hoosiers) 255; wheels (volk rays) 18 – 9.5
Controls & safety
race bucket seats (sparco corsa); seat brackets + slider (sparco)
steering wheel (sparco 383); quick release bolt in (sparco); steering boss (sparco)
4+2 harness (sparco)
floor mount alum. (sparco)
4 gauges + controller (Defi); gauge holder (front pillar); turbo timer (apexi); rev. limit indicator (defi)
ignition kill; fire extinguisher system (lifeline2000); roll-cage (cusco)
Interior accessories
carpet (Lancer stock); dashboard + center console paint (red); foot pedals (sparco); gear knob (sparco); oil cap (hks); center console (gauges)
http://www.imagehosting.com/show.php...02421.jpg.html
http://www.imagehosting.com/show.php...02362.JPG.html
http://www.imagehosting.com/show.php...02312.JPG.html
http://www.imagehosting.com/show.php...G0230.JPG.html
http://www.imagehosting.com/show.php...02292.JPG.html
http://www.imagehosting.com/show.php/522810_IMG02421
http://server6.theimagehosting.com/i...G_0335.ae0.JPG
http://server6.theimagehosting.com/i...G_0333.86d.JPG
http://server6.theimagehosting.com/i...G_0326.856.JPG
http://server6.theimagehosting.com/i...G_0324.1c4.JPG
http://server6.theimagehosting.com/i...IMG_0264_2.JPG
http://server6.theimagehosting.com/i...IMG_0258_2.JPG
http://server6.theimagehosting.com/i...IMG_0242_2.JPG
http://server6.theimagehosting.com/i...0242_2.1c5.JPG
Old Apr 25, 2007 | 11:00 AM
pltek's Avatar
alright show us the dyno graph
Old Apr 25, 2007 | 11:06 AM
CaymanEvo3's Avatar
+1
Old Apr 25, 2007 | 11:43 AM
norcalevo_3's Avatar
+2
Old Apr 25, 2007 | 12:07 PM
ssiempre's Avatar
+3
Old Apr 25, 2007 | 12:11 PM
LancerEvoMR's Avatar
AGAIN, USE & EDIT YOUR ORIGINAL THREAD:
https://www.evolutionm.net/forums/sh...d.php?t=266446
Closed.
Compjoc
19
Aug 5, 2008 08:15 PM
Justin1933
For Sale - Cars For Sale
18
Sep 11, 2006 01:18 PM
yesevo
Jun 7, 2006 07:59 AM
sgplancer
Apr 19, 2006 01:34 PM
danalo
Jan 1, 2005 07:42 AM
