Where is the coolant drain bolt on the block?
Old Apr 25, 2007 | 03:27 PM
milo's Avatar
I'm trying to drain the coolant from the block. Does anyone know where the bolt located? Tia
Old Apr 25, 2007 | 03:29 PM
Toddevo 8's Avatar
look on the radiator on the right side of the car, that is all you will need
Old Apr 25, 2007 | 04:03 PM
gsrboi80's Avatar
+1 Than I start the car put a hose in the rad and let it heat cycle untill it flushes all old coolant out of the block.
let it drain and refil the Radiator
Old Apr 25, 2007 | 05:53 PM
96_LXR's Avatar
I was going to post a pic but Image Shack no worky.
The drain on the block is underneath the radiator hose as it goes by the drivers side of the car. I'll post the pic if I can.
Old Apr 25, 2007 | 05:56 PM
hondafan's Avatar
it's in a place that's a PITA to get to it near the water pipe. i just left what was in the block, it's not much. i got 1.5 gallans out give or take which is close to the system capacity just using the plug on the rad.
Old Apr 26, 2007 | 06:40 AM
DanJ's Avatar
If I remember you want to flush with distilled water.
Old Apr 26, 2007 | 12:45 PM
trinydex's Avatar
yeah but no matter what you do you'll get minerals and stuff from other places... it can't be helped... best is to service at the right intervals
Old Apr 26, 2007 | 02:49 PM
barneyb's Avatar
Its on the back side of the engine toward the passenger side with about everything possible in front of it. I looked and that was enough for me. I've never heard of anyone actually removing this when draining coolant.
Old Apr 26, 2007 | 06:25 PM
gsrboi80's Avatar
+1
I know what hes talking about there is abolt where you stick the ratchet staight into. Its right next too where the lower rad hose goes to the block.
I have never taken it out to flush out the syetem. I just heat cycle it a couple times unill it runs clear then fill it up with a little more coolant than water to compensate for whatever straight water might be in the block.
Old Jul 11, 2007 | 08:08 PM
Johnboy1065's Avatar
its an 8mm alan key plug on the intake manifold side of the block right under the number 4 cylinder freeze plug. its about impossible to get to unless you take out the passenger side axle. then you can reach from underneath. But still HARD to get to and its torqued in there to about 35 ft lbs too. Probably not worth the effort for how little coolant is left in the block after draining the radiator.
Old Jul 12, 2007 | 06:48 AM
Joshs EVO's Avatar
So on this topic of colloant does anyone know where toplace an aftermarket water temp gauge plug. I had one guy tell me he drilled into the radiator hose connector(the thing the hose connects too, not the hose itself) on the drivers side. I have the gauge just sitting in my garage and it needs a good home.
Old Jul 12, 2007 | 06:49 AM
Joshs EVO's Avatar
Coolant...sorry
Old Jul 12, 2007 | 06:58 AM
pbevo12's Avatar
a few friends of mine use =GT-Spec Radiator Hose Adapter for Evo 8 & IX
GT-Spec 32mm Radiator Hose 1/8PT Adaptor:
Cut your radiator hose, slip this in there, and it has a fitting for Defi water temperature sender. You have to cut the radiator hose to use this.
jsc sells it under gauges section
Old Jul 13, 2007 | 11:56 AM
KFC-AWD's Avatar
42draftdesigns makes this to replace the upper part of your thermostat housing http://42draftdesigns.com/product/42919.htm .. you just put the sensor in the top of it and put it back on like the normal thermo top housing. Its a lot better than using one of those adapters in your rad hose.
Chrushev
Jul 25, 2017 11:43 AM
EVO10190
Aug 12, 2015 03:49 PM
fuzzychi
Jun 21, 2010 06:31 AM
LetsGo82nd
May 30, 2008 06:34 AM
Eclipsing
15
Nov 8, 2007 08:11 AM
