Methods of Reducing Rotating Mass Weight
Old Apr 28, 2007 | 06:53 PM
_EVOlved_'s Avatar
Indeed...
Old Apr 29, 2007 | 06:22 AM
Kryptonite's Avatar
We did this to our ring gear recently to lessen rotating mass (note: this ring gear is NOT in the Evo, but you get the idea)
Started as 12 lb, machined 4.5 lbs off of it.....quite a common practice for 9" ford rear ends
Old Apr 29, 2007 | 06:30 AM
Azntoyhere's Avatar
Smaller battery will definitly take a good 20+lbs more off your car i would say. Stock is what 30+? near 40. There is a battery out the is weighting only 11.5-12 lbs. so good crap. i forgot the name of the battery but i was watching a video and damn that is small as hell.
Old Apr 29, 2007 | 07:56 AM
hotrod2448's Avatar
What does the battery rotate around?
Old Apr 29, 2007 | 09:24 AM
_EVOlved_'s Avatar
Odyssey batter is what i use
Old Apr 29, 2007 | 11:07 AM
Saenek's Avatar
They're talking about rotating weight here guys...
Old Apr 29, 2007 | 11:12 AM
jroller's Avatar
dont forget your engine internals lightened rods and crank. Will add power too.
Old Apr 29, 2007 | 11:50 AM
EvoEvol's Avatar
Does anyone know the weight of MR BBS wheels minus tires?
Old Apr 29, 2007 | 12:12 PM
gsrboi80's Avatar
Take out AC and PS and mostly as mentioned wheels, tires, flywheel clutch, Balance shafts
Old Apr 29, 2007 | 03:34 PM
_EVOlved_'s Avatar
Is it a factor of x8 or x4 for rotating mass compared to regular weight?
Old Apr 29, 2007 | 03:39 PM
Vigo's Avatar
17.74 pounds.
Old Apr 29, 2007 | 03:40 PM
_EVOlved_'s Avatar
Whats the weight of the IX ones then without tires?
Old Apr 29, 2007 | 03:41 PM
Vigo's Avatar
Good thread.
Old Apr 29, 2007 | 03:42 PM
Vigo's Avatar
20.17 pounds.
Old Apr 29, 2007 | 03:44 PM
Vigo's Avatar
Get some Rays Engineering lug nuts and locks too. These will reduce weight by about 1 pound per wheel.
