Methods of Reducing Rotating Mass Weight
Old Apr 28, 2007 | 11:39 AM
_EVOlved_'s Avatar
Post Methods of Reducing Rotating Mass Weight
Hey all...
Im working on getting the RS light for more power and speed. I have a list of what I am going to do to reduce the overall weight. I want to get the car faster on both the stripe AND DYNO. I know to put down more whp, one must reducing their ROTATING MASS weight. I made a list below.
1. Lighter Wheels / Tires / Lug Nuts
2. Carbon Fiber Driveshaft
3. Lighter Flywheel / Clutch
4. Lighter / Smaller Brakes
5. Inflate Tires
6. Lighter Suspension
7. Lighter Internals
What else can one do to reduce their rotating mass?
Are there any other methods to get faster and put down more power besides overall and rotating weight reduction?
Thanks!
Old Apr 28, 2007 | 11:44 AM
ambystom01's Avatar
Lighter tires and lighter suspension comes to mind.
Old Apr 28, 2007 | 11:51 AM
hotrod2448's Avatar
Light weight flywheel.
Reducing rotating weight isn't the only way to make more power. There is always more displacement and/or a bigger turbo.
Old Apr 28, 2007 | 12:00 PM
qnz's Avatar
qnz
smaller brakes
Old Apr 28, 2007 | 12:01 PM
MrEvo2U's Avatar
There is a lot of weight you can take out of the rotational mass of a 4G63 crank/rods/pistons
Old Apr 28, 2007 | 12:56 PM
EVO8904's Avatar
Helix V2 cams and cam gears
Old Apr 28, 2007 | 01:03 PM
Jasil's Avatar
Being a miser I'm more concerned with hp/$$ quotient. It's much easier and cheaper to add hp than reduce weight if you want to keep the interior.
Old Apr 28, 2007 | 01:13 PM
fromWRXtoEVO's Avatar
Pulleys, tires, rotors,rims, better shyntetic various oils, proper inflation of tires would help even though is more like a friction issue than rotational weight but it is always underlook..
my .2c
Carlos
Old Apr 28, 2007 | 03:30 PM
Robevo RS's Avatar
^ +1
Old Apr 28, 2007 | 03:33 PM
Blue Evo 8's Avatar
Originally Posted by _EVOlved_
Hey all...
1. Lighter Wheels
3.
4.
5.
Thanks!
CF driveshaft is very expensive.....
Old Apr 28, 2007 | 03:34 PM
_EVOlved_'s Avatar
Nice...Any more?
Old Apr 28, 2007 | 03:51 PM
Jim in Tucson's Avatar
1. Lighter Wheels
5. Inflate Tires
Lighter weight tires are the most important, the least expensive, and easier to change out than any item on your list.
Remember with tires:
A. Whatever weight you save is X4.
B. Tire weight is at the largest radius point of all the items.
Wheels and tires are liken unto 4 large flywheels that have to be spun up every time you accelerate. And, slowed down every time you brake.
I'm always amazed at car owners who would never add 4 additional heavy flywheels to their prized 'enthusiast' car, but will add a set of heavy tires on even heaver wheels.
Old Apr 28, 2007 | 05:05 PM
_EVOlved_'s Avatar
I thought for wheels and tires its a factor of X8 right?
Old Apr 28, 2007 | 05:08 PM
Ultimate CC's Avatar
I would do wheels and tires first...your not sacrificing anything but gaining a ton...
Old Apr 28, 2007 | 06:28 PM
Bonestock!'s Avatar
Without a doubt unsprung weight and rotational mass are the most important areas to loose weight.
You don't really need to get smaller brakes but the 2 piece Giro disc and Performance Friction rotors are like 2-3 pounds lighter than stock. I'd say those and a set of MR BBS wheels (2.8lbs lighter than the standard RS & IX wheels!) would knock off a good bit of weight right there.
