Lower heat shield--O2 install
Old May 9, 2007 | 06:11 PM
Zoxygen's Avatar
I'm installing an O2 housing and was wondering anyone who's done it before has gotten the lower heat shield off.
I have stock radiator and I've heard of people doing it without taking it out.
I have all the bolts out and the heat shield is just hanging there but I can't lift it out
Any suggestions?
Old May 9, 2007 | 08:36 PM
J Nasty's Avatar
i broke the bolt off with a prybar and mallet then tore out the sheild
Old May 9, 2007 | 08:39 PM
EvosnatcH's Avatar
go to evomoto's website they have an install guide, i took my rad off when i did mine i also had to cut the bolt closest to rad to get it on (invidia o2 not sure about others), if you decide not to take out the rad make sure to tape some cardboard on it so you dont dent the fins.
Old May 9, 2007 | 08:48 PM
ries's Avatar
if your not going to use the o2 housing heat shield again just use some tin snips to cut it off...
then the hotside and o2 housing should come off fairly easily...
haoma12's Avatar
busted my radiator while yanking off the bottom heat shield and yes i was installing the O2 housing... DIdnt notice it was busted until i started driving it and it was shootin coolant on my windshield. loL my answer to this probably was KOYO radiator for 335 bucks!
Old May 9, 2007 | 09:20 PM
RoadSpike's Avatar
If the heat shield is going to be a complete pain you may as well unbolt the downpipe and manifold. Then take off the hotside clamp, a gentle tap with a hammer should loosen it so you can take the whole hotside and o2 outlet out. If you disconnect the plug from the o2 sensor under the cam cover you can take the unit out as a whole and possibly spare your radiator.
FYI, I never put my lower shield back on.
Old May 9, 2007 | 09:52 PM
Zoxygen's Avatar
Alright I got it out,
But in the process I bent some radiator fins. and a few bent fins all that bad? I'm almost certain I didn't puncture the radiator but I deffinently should be able to tell if I did when I start up right?
I don't think I could of punctured it, the only part of the heat shield that touched it was a bulge so it was blunt.
Old May 9, 2007 | 10:04 PM
RoadSpike's Avatar
No you wont be able to tell on start up if its not leaking now.
If by some SLIM chance it develops a pinhole it probably will be under pressure so when its fully warm.
haxr303
Jun 4, 2018 08:16 PM
Nimpoc
20
Sep 10, 2014 11:08 AM
fid
Apr 9, 2012 07:49 AM
reboundicon
Apr 20, 2011 04:20 PM
500whp.com
18
Jan 23, 2008 04:37 PM
