EVO - Ipod users!
I just got a new Ipod and Im wondering if anyone has used this setup. Its rather cheap and looks great! I am wondering if it will work with the stock head unit and also how difficult it is to install.
Its made by Harmon Kardon.
Here is the ebay link: http://cgi.ebay.com/Harman-Kardon-Dr...QQcmdZViewItem
My friend has that setup and it's bad ***. The install wasn't bad and I'm guessing it could be used with a stock evo HU. He's using it in his nissan with the stock nissan HU.
I'm using the alpine 9857 and it works pretty good but if I had to do it over again that is the way I would go.
Based on its apparance and the eBay description, not having actually seen it, here's what I think you'd get with the Harmon-Kardon:
All else being equal, I think the Alpine approach is cleaner. I just wish it had better and faster iPod controls. YMMV.
- Nice interface and controls
- Mediocre sound quality if wired through the antenna; fine if wired through the auxiliary inputs of a stereo (none on the OEM stereo unless you hack the CD changer jack
- Difficulty locating the control unit and display -- maybe put them in the cupholders?
- Low cost
- Nice display
- Higher cost
- Need to get a cheap set of Mitah cables to feed the SSL amplier--not needed with base stereo
- includes good cheap amp upgrade to base stereo
- Nice head unit
- Confusing iPod interface and poor display of what's playing -- only one line of data at a time
- Very slow scrolling through my massive (80-gig) iPod
- Easy to hide the head unit by mounting it in the lower DIN slot
- Good sound quality using the Alpine dock connector cable
- no need to mount a bunch of extra equipment here and there
i did a write up on this setup a while ago...albeit it was with an aftermarket HU
https://www.evolutionm.net/forums/sh...on+kardon+ipod
I am using an Alpine deck IVA 901, and I would have to say that its just ok. I have to use playlists and just scroll through them using the FF button, kinda sucks, I can not see a list of songs and choose a particular song that I like. Technology hasn't advanced as far as I thought it would have by now
Maybe there is some newer iisshh out there now but I already spent about 4k on my system.
I just had one of the monkeys at Best Buy do it up at the same time I was getting my alarm installed. I'm not good with electronics. If there's something to bolt up or screw on, I can usually handle it, but wires...meghhh.
You basically buy the headunit + cable that goes into back of head unit and connects to your ipod. I don't think hardwired is the correct term, but it sounded better than "kinda sorta plugs in to"
Carlos
If you care about sound quality, your best bet is an aftermarket head unit with direct iPod connection. If you don't care about sound quality all that much, this Harmon unit should be fine. If you can, buy it at your local Best Buy or order it from Crutchfield and give it a shot. If you don't like it, just return it and get a new head unit/ipod adapter.
I installed that setup in my wife's Explorer about 8 months ago. The interface is awesome, the screen and controls look like they're from a much more expensive setup.
Install is easy and the hardwired (AUX in) sound is great. The FM modulator, however, is disappointing, even with the direct antenna wiring. Now, I don't think you're ever expecting crazy good sound with an FM modulator, but you'll be pissed after spending $150 on this if it doesnt sound great.
Since you're not gonna have an AUX in, I suggest picking up a new CD player with built-in iPod compatibility. It will be similar in price (you don't need a top-of-the-line anymore for iPod compatibility) and you'll get the direct input.
Althought the fact that it is one kinda defeats the purpose of that
the oem adapter is a compromise... i could see why a setup like this one would be desireable... but it's not necessary for someone like me :\
i don't know why people put songs they don't wanna listen to on their ipods but if you are one of those people the oem style ipod turned into a cd type units aren't for you.
an more simple way and cheaper method, were to just buy an aftermarket headunit i myself stay with pioneer and wire it from the rear were you use an auxilary wire , then buy a cheap male to male wire and there you go. one end goes to the headunit the other to the headphone jack of the ipod and it sounds crystal clear. thats the way i have been running mine for over a year or so now no problems what so ever.
the only problem with that is you don't get to charge...
admittedly the oem style adaptors kinda suck because it removes your control over the ipod but... i guess that's good because you don't wanna be starin' at the ipod when you drive.
No, it won't work w/ the stocker.
I had one of these installed about a year ago - over $500 including the HU but worth every nickel.
BTW, don't try this installation yourself...
[TYPE]SS
10
Dec 13, 2009 11:35 AM
RalliArtEvoVIII
Apr 16, 2007 12:17 PM
AhmadHasib
17
Jan 30, 2007 09:02 PM
