RIP Evolution --- [PICS INSIDE] PLEASE HELP!!!!!!!!!!!
Old May 16, 2007 | 06:27 PM
  #46
zze-131's Avatar
Other cars (non evo) I've worked on with a similar problem turn out to be shift linkages out of adjustment. They'll shift into 135 or 24R depending on how they're out.
Then again, you mentioned it wouldn't engage the entire bottom row or 5th so then the possibility of clutch does come up. I guess we'll see soon enough.
Old May 16, 2007 | 06:44 PM
  #47
EvoJoeIX's Avatar
Originally Posted by ndylam
Its not worth spending $1400 for another stock clutch. If they won't cover you under warrenty then fack them. You should just get an exedy twin clutch if you gonna spend that money. It worth every god damn penny buddy. Beside you gonna need this mod in the future anyway. Unless, you planning on driving it stock.
Cheers
he just spent over 30 grand on a car and it breaks.....
now if it was you would you jsut be like, ok ill put out 2 grand for a new clutch?
id be pissed, that should be covered under warranty, dont let them pressure you into paying for it yourself
Old May 16, 2007 | 06:55 PM
  #48
HugeinJapan's Avatar
This happened to me. Dealership wanted 1k+ $ to replace my clutch. I told em to fk off and tow it back to my house. I took out my battery tray. Took off the hydraulic line underneath there. Ended up being a crack in the line under the sleeve where it threads on. Bought a straight line and bent it up to fit. Screwed it on. Ta-da! 2 bucks. I would check that out.
Old May 16, 2007 | 06:56 PM
  #49
cssaddictm4's Avatar
Sounds like a lemon to me. I would not take no for an answer in regards to fixing the problem, how long have you had the car?
Old May 16, 2007 | 06:58 PM
  #50
Actually Is your clutch peddle dead to the floor? If not then nm.
Old May 16, 2007 | 07:00 PM
  #51
BocaShula's Avatar
dude... that sucks.
Old May 16, 2007 | 10:37 PM
  #52
VictoryEVO's Avatar
I was a dealership mechanic for8 years (Dodge and Volkswagen). I would tell you not to worry but its an Evo! A buddy of mine is a mitsu tech at a local dealer and he said Mitsu has a clause in the Evos warranty where they will not cover a clutch ever. But some guys on here are saying they have had thiers covered. I think it all depends on the service rep that comes out to approve or deny your warranty claim.... Good Luck!
Old May 17, 2007 | 12:02 AM
  #53
evo_tiago's Avatar
any update on the car bro?
Old May 17, 2007 | 12:11 AM
  #54
bsander23's Avatar
sad.......car look good though!! i remember last time mine was on a flat bed...being delivered to me......looked real good. that is an interesting clutch story I would be curious to see how that ends up. good luck!
Old May 17, 2007 | 03:02 AM
  #55
EVORaab's Avatar
It was in Ohio where she died on me. So we flat bedded it to a dealership here in PA. Bairel Mitsubishi. They have a mechanice, Mike, who only works on EVOs...he gets them from all over the place. He himself has a modded evo and he says basically nothing voids the warranty, he seems super cool. He is gonna call us today, it didn't get there til' late yesterday.
I will keep you guys posted!!!
PRAY!
Old May 17, 2007 | 03:23 AM
  #56
jtbluebeast's Avatar
Personally I think that if it were any of the simple problems then there wouldn't be a sound at all. Bushings being out don't make any sound at all you just lose a row of gears. If it sounded like something rattling around in the casing then worse case scenario is a shift fork, or less of a pain in the **** a flywheel bolt has vibrated lose and lodged itself between the flywheel and sprung hub on your clutch plate. If it is the latter then all that is needed is removal of tranny, clutch, retorque all seven flywheel bolts, realign clutch, and reassemble. May take about 3-4 hours. Speaking from experience here. But good luck with whatever it is.
Old May 17, 2007 | 05:29 AM
  #57
smarsenal's Avatar
Is your car completely stock? That looks like a bigger FMIC there. If not, let us know what the dealer says. Good luck man!!
Old May 17, 2007 | 06:47 AM
  #58
AlwaysinBoost's Avatar
From your description it doesn't sound like a clutch problem. but whatever it turns out to be it SHOULD 100% be covered under warranty if you car is completly stock and there is no signs of abuse. If they try and tell you anything different DON'T roll over and take it, fight them.
Old May 17, 2007 | 07:13 AM
  #59
filter's Avatar
im almost crying seeing those pics.
Old May 17, 2007 | 10:42 AM
  #60
sabastian458's Avatar
There isnt a "clause" for the evo clutch. They have the EXACT same warranty for clutches for ALL of their vehicles. 12/12 of a manufacture's failure, not for being burnt/slipping/chattering etc. If the throw out bearing clip breaks (which I have seen on a new evo w/6k) then it would posibly be covered. If he has any performance mods on the car and it is burnt, give it up they wouldnt and shouldnt cover it.
