Evomoto Diy Egt Install
Old May 18, 2007 | 12:46 PM
DavidVIII's Avatar
Question Evomoto Diy Egt Install
Hello people, tomorrow I'm planning to go for the DIY installing the EGT, just wanted to know anyore here (wish I think) has done it..
and if there any tip for instance or something that I should be awere of it.
thanks for any replay that I get
I have to be honest I'm just scare that a piece of metal actually fells into the pipe and the goes inside the turbo
Old May 18, 2007 | 12:58 PM
91GSX's Avatar
If you drill into the manifold with the car running it will push any bits out.
Old May 18, 2007 | 01:00 PM
mikesevo8's Avatar
^^^^^ +1 That's how I did it. Followed evomoto's directions, and it worked for me.
Just use plenty of oil while drilling, and take your time once you get ready to break through.
The exhaust will blow all the shavings out.
BTW - wear gloves - those little shavings get hot...
Old May 18, 2007 | 01:04 PM
91GSX's Avatar
DO NOT WEAR LATEX GLOVES
no doubt, drilled & tapped countless DSMs this way in the past. I just checked out the evomoto write up & it is a really good write up. Unless you want to take the time to take the manifold off..... just drill/tap it.
Good luck with the install bro!
Curt@MrLed's Avatar
Former Vendor
and what happens if one doesnt get blown out, into the turbine it goes... thats a really bad idea for doing the job.. do it right and take the manifold off..
Old May 18, 2007 | 01:33 PM
91GSX's Avatar
/\ /\ /\ safest & most time consuming method hands down. If you have the time take the manifold off & why not port it while you have it off.
I guess I was just very lucky in the many installs that I have done over the last 10 or so years without even the slightest issue. So were the countless others who have drilled at idle slowly & cautiously.
Either way that you do it..... take your time.
Old May 18, 2007 | 06:29 PM
DavidVIII's Avatar
damm... I just dont want to break the turbo...
and since I work tomorrow until noon, I just dont know how much time will it take to cool down to get it out..
FiReBReTHa
Lancer How Tos / Installations
Jul 18, 2016 08:07 PM
luvboost
Jun 23, 2011 01:51 PM
Evoluvin
Jan 12, 2009 04:45 AM
SlowCar
Dec 3, 2006 09:22 PM
racerferrari
Jan 8, 2005 11:17 AM
