Spark plug which n When
Old May 28, 2007 | 10:15 AM
EVO MR FU's Avatar
How often should spark plugs should be changed? I have about 310whp and drive spirited most of the time.
I have an evo 8 and I wondering what would be the best plugs? what are you guys running with around same power?
Thanks
Old May 28, 2007 | 10:46 AM
BluEVOIX's Avatar
I'm still learning about the evo but so far what I know the stock plugs are Iridium.
When I change them out, I'll probably get copper plugs with stock heat range. For the coppers, I would change them every 6,000 to 9,000 miles (every 2nd or 3rd oil change). Copper wears out quicker but are a lot cheaper to replace and they are pretty good for Turbo aplications. What ever you do dont get Platinum, something about the material not being able to withstand the heat and pressure from turbo cars.
Old May 28, 2007 | 08:25 PM
SteelEvo's Avatar
I run ngk br8es 1.5 step colder plug...I change them out every 6k miles
Old May 28, 2007 | 10:16 PM
EVO+IX+MR+SE's Avatar
you guys are just wasting money. spark plug this days can last more than 100k. Im a BWM tech. and we barely change any spark plug at all.
Old May 28, 2007 | 10:17 PM
Warrtalon's Avatar
The answers to these questions are the same as the ones given in all the other threads asking the same questions.
Old May 28, 2007 | 10:19 PM
Warrtalon's Avatar
Most BMWs don't run high boost that gets turned up even higher after modding. The stock plugs do not hold up to that abuse, because they are Iridium as opposed to copper.
Not sure why you'd pre-suppose that your BMW knowledge carries over to a 4-cyl 2.0l cast-iron 4G63 running 20+psi.
Old May 28, 2007 | 10:21 PM
mac_05evo's Avatar
Drive my car for a 100k miles and get back to me on that one.. I typically change mine every 3-5k miles..
Old May 28, 2007 | 10:28 PM
evo150's Avatar
ngk bpr7es gapped to .026 and changed every other oil change
Old May 29, 2007 | 05:01 PM
will bmw also got twin turbo...that are pretty fast and they do go through spark plug like that.
Old May 29, 2007 | 05:03 PM
chaotichoax's Avatar
running what like 6 psi?
stop trying to argue this
a bmw is not an evo
Old May 29, 2007 | 05:21 PM
lords3t's Avatar
wow.. .this is a bit surprising to me. My car is stock still and so I thought I could trust the suggested 'severe' maintainence schedule that came with the manual.
Old May 29, 2007 | 05:32 PM
Warrtalon's Avatar
You don't have to touch the plugs if you're stock - that's not what we're talking about.
Old May 29, 2007 | 07:04 PM
Redline-Z's Avatar
Veteran: Air Force
Ok, I have bolt-ons and a flash do I still have to change them every 6K? I take care of my car and do TC, Tranny, Diff at 6K also. this is going to make an even bigger dent in my pocket. And yes I drive it hard! I guess I am asking what do the gurus do?
Old May 29, 2007 | 07:10 PM
Warrtalon's Avatar
Why in the world would you change the trans fluids every 6k? No reason to do that unless you track (road race) your car heavily. No one is supposed to just randomly change their spark plugs - you change them when they foul out, and that is only going to happen with copper plugs. You should still be using the stock plugs for as long as possible until they no longer work properly. After that, consider getting copper replacements and changing them as needed.
I don't think $8 is much of a dent in your pocket, though. That's all a set of copper plugs costs...
Old May 29, 2007 | 10:34 PM
VictoryEVO's Avatar
+1
