A/C Problem
Old Jun 18, 2007 | 04:35 PM
One Wicked EVO's Avatar
i work at the dealer your a/c has nothing to do with any other thing you could have installed unless you messed something up while putting something in, but they might void the rest of your warrenty that you did touch in case you come in with a problem down the road
Old Jun 18, 2007 | 04:38 PM
JordanS4's Avatar
That's what I meant, the entire warranty will probably be voided if I go to the dealer with the mods I have. If its not going to be an expensive fix I'd rather avoid demodding and going to the dealer.
Old Jun 18, 2007 | 04:43 PM
have you checked fuses? do you hear the clutch come on on the compressor? stop trying to add or take freon out check all basics first
Old Jun 18, 2007 | 04:48 PM
VictoryEVO's Avatar
Originally Posted by JordanS4
Yeah that's 100 psi on the low side and I've never touched it before taking that picture today. If the CC isn't cycling, what am I looking at in terms of repairs ($ wise)
Low side pressure is way too high if the compressor is cycling. I would have to see the High side pressure to tell anything. If the pressures are both around 100 the compressor is F'ed. Hard to diagnose without hands on and the proper equipment. Some independent shops only charge 50 to 120 bucks for A/C service or diagnosis.
GOOD LUCK!
Old Jun 18, 2007 | 04:54 PM
JordanS4's Avatar
when would i hear the clutch come on? right when the a/c is turned on and the entire time it's running? all the fuses look good btw
Old Jun 18, 2007 | 06:10 PM
BBS's Avatar
BBS
STOP adding more into the system please! A/C systems can/are very delicate. You must properly evacuate the system before you add anymore in. Take it to your local auto repair shop that can diagnose the issue.
ES_02
Lancer Troubleshooting
11
Jan 2, 2024 04:24 PM
Lumpy
Sep 2, 2010 08:34 AM
ohEVO18
Aug 20, 2010 07:32 AM
jrome_91
Aug 10, 2010 09:16 PM
Evoisdream
Sep 12, 2005 01:30 PM
