Help car won't start after installing fuel pump and injectors
Old Jun 26, 2007 | 06:56 PM
  #31
Joshs EVO's Avatar
Ok I just took out the new injectors and it still does not work. There seems to be getting fuel since it poured out on me. Now I don't know how much should be coming out, so I will check the fuel pump again. The wires/connectors to the pump are pretty self explainitory theres only one way it will go in.
Old Jun 26, 2007 | 06:58 PM
  #32
Joshs EVO's Avatar
Your an idiot. Answer me how I am supposed to get the car to the shop and geta tune if the car wont start with the stock fuel pump and stock injectors in. Idiot
Originally Posted by threefiftyse7en
go get it tuned for goodness sake!
Old Jun 26, 2007 | 06:59 PM
  #33
Joshs EVO's Avatar
South Korea sucks too, i've been there.
Old Jun 26, 2007 | 07:11 PM
  #34
Ivan@AMS's Avatar
with the issues I listed in my other post, you will still get fuel to the rail but it wont be at a high enough pressure to provide enough fuel for your car to start. Most important thing to check is where the pump outlet meets the fuel sending unit. Make sure the rubber sleeve is not ripped, and is correctly seated on the pump.
Old Jun 26, 2007 | 07:19 PM
  #35
Joshs EVO's Avatar
ya put the pump back togther just how it came and still nothing. I just tried. it does the same thing. The car trys to start like the MAF sensor is not hooked up, which it is. if you know what I am talking about. I may just tow it to the shop and spend my tune money on getting the car fixed. This sucks.
Old Jun 26, 2007 | 08:19 PM
  #36
Nad1370's Avatar
Okay..let's make this simple. 2 things to start a car.
1. Fuel --which you claim you have. But is it getting in the cylinders. Plugs wet or dry?
2. Spark--??
Figure this 2 out and let us know.
Do you have SES light up when key is in the "ON" position?
Old Jun 26, 2007 | 08:27 PM
  #37
dsmjeffro's Avatar
2. Spark--??
def start off with this then make sure you have fel fressure try & let the pressure out when i did my intake manifold i had the same problem & it turned out that i tore the o ring on the end of the fuel rail taking the line off & the pressure was leaking out there for not giving me enough pressure for the fuel system to opperate properly try it hope it helps
Old Jun 27, 2007 | 05:58 AM
  #38
Joshs EVO's Avatar
yes I get the SES light, I unscrewed the 2 bolts that hold on the fuel rail and had my wife start the car. I saw gas spilling out, so there is gas getting to the cyclinders. I have checked the O rings and the other rubber pieces that go into the block. they are all ok.
Spark seems to be fine. spark plugs are a relativley clean and do not smell of gas.
Old Jun 28, 2007 | 02:27 PM
  #39
Nad1370's Avatar
^^Gas is getting to the rails but I don't think your injectors are opening since the plugs aren't wet.
Something electrical.
Go back track everything you did and re-check all fuses and connectors that inhibit injectors from pulsing.
Old Jun 28, 2007 | 06:15 PM
  #40
Joshs EVO's Avatar
so where is the fuse that controls the injectors. I will go out and check right now if someone can tell me where it is. The only fuse right off hand that I can think of is the engine control fuse in the engine compartment. But that may go to the computer. So someone tell me where the fuse of whatever controls the injectors.
You may be right.
Old Jun 28, 2007 | 06:42 PM
  #41
COEVOPOWER's Avatar
Ya need Engin Mangament.....
Old Jun 28, 2007 | 06:55 PM
  #42
Joshs EVO's Avatar
another retard adds his two cents, read all the posts, then call your local shop
Old Jul 5, 2007 | 02:12 PM
  #43
Joshs EVO's Avatar
OK, brought the car to the shop and they checked everything I checked before and this is what they told me a while ago. They are at the last thing they can do basically. They are taking the car to the Mitsu delaership cause they THINK the key code was erased due to my changing out the fuel pump and injectors. Don't ask me how but that's what they said.
Has this happened to anyone else before? Is it common to happen
Old Jul 6, 2007 | 12:15 AM
  #44
mitsuorder's Avatar
Bad fuel pump maybe? I just installed a walbro in a car the other day that was bad out of the box. The car exhibited the same signs as you are describing.
Old Jul 6, 2007 | 12:54 AM
  #45
EVO9_IX's Avatar
are you getting an engine code ? try it out man , double check your work again it sounds like something simple
