wiring a mecanical autometer Boost gauge? need help
Old Jul 11, 2007 | 05:08 PM
Kevin Knight's Avatar
i couldnt find any real good explnations on how to hook up the 12v to the gauge. some people have said you need to get a hook up wire at autozone or something. can anyone explain. i want to hook it up into the fuse box and not split any wires? can someone explain what i need to do? thks
Old Jul 11, 2007 | 05:10 PM
Lancematic's Avatar
Add-a-fuse link from pepboys or autozone plugs into a socket for an existing 12v fuse and replaces that fuse while adding a fused hot wire to connect to. Ask at the parts counter for one for mini fuses
Old Jul 11, 2007 | 05:14 PM
spooch's Avatar
did the same thing for mine today, the gauge works well, needed to zip tie multiple times, i ended up using 4 zip ties to hold the boost hose on the tee, i had 2 or 3 on and at 23lbs it was flying off
Old Jul 11, 2007 | 05:18 PM
i still dont understand how to wire the gauge up. the kit comes with nothing. and iv never done any type of wireing before. what do i need to go buy?
Old Jul 11, 2007 | 05:30 PM
Kdash106's Avatar
i just installed my electronic Boost gauge last night, it was my first wiring DIY too. very easy i just tap in to the digital clock harness. it's got all the wire you need to hook it up. i used to have a AM boost gauge, i think it only have 2 wire. the ign, and the light. but i didn't install that.
Old Jul 11, 2007 | 05:46 PM
Usedcarfinders's Avatar
I know you said you do not want to splice, but if you simply splice into the windshield wipers wire and ground it its a nice solid connection that shuts off when the car is off
500evo
Mar 21, 2012 02:09 PM
wags528
Oct 14, 2009 08:15 PM
MrFairlady
Feb 24, 2006 06:17 PM
AWDTurbo4
Oct 14, 2005 09:29 AM
soule77
Dec 17, 2004 04:55 PM
