UGH so close
Old Jul 14, 2007 | 12:12 PM
Blizzackk's Avatar
UGH so close
So I was going to pick up the evo today...2006 IX Electric Blue SSL. But we drove it one more time and we noticed a slight whirring-whiney noise when the clutch was engaged. When you push in the pedal though it disappears, we are thinking it might be the bearing. So the guy is taking it to the dealer on Monday to get it all fixxed up for us. getting it for 26k with 17k miles. It also has these crappy rotors on it that pull to the right when breaking, but I will prolly just put the OEM ones on myself.
Basically, I just wanted to make sure that the whirring isn't too huge of a problem (fingers crossed/knock on wood) and hopefully on Monday I will post up pictures of the sexiness.
edit: crap i forgot to put this in noobie section... Sorry
Old Jul 14, 2007 | 04:54 PM
Mellon Racing's Avatar
my 05 makes a little noise, always has
Old Jul 14, 2007 | 05:04 PM
Redline-Z's Avatar
Veteran: Air Force
Chatter it is nothing to worry about if it goes way when the clutch pedal is depressed mine did it since day one
Old Jul 14, 2007 | 05:38 PM
W0459732's Avatar
26k for a car with 16k miles. U can almost pick up a new 9 for about 31k, but then again its an extra five grand. Is the car modded?
Old Jul 14, 2007 | 06:14 PM
SHhhhh's Avatar
probably throw out bearing. mine sounds worse when AC is on.
Old Jul 14, 2007 | 06:15 PM
1320 Engineering's Avatar
nothing to worry about... my car does the same thing +1 for worse with a/c
Old Jul 14, 2007 | 06:30 PM
tony_b's Avatar
Mine has always done it as well.
So this is what you do. When he gets it back from the dealer, go there and tell him that it's still not "normal" and offer him $2K less because you'll probably have to replace the clutch soon.
Old Jul 14, 2007 | 06:39 PM
Boostin4g63's Avatar
My 03 evo VIII does the same... when its ideling it makes that noice but when i press the clutch in it goes away!!!!!! NO WORRIES bru
Old Jul 14, 2007 | 10:17 PM
VictoryEVO's Avatar
Same here I thought I was crazy!
Old Jul 14, 2007 | 11:29 PM
Nuked's Avatar
I didn't think they made a IX in blue?
SQ
Old Jul 15, 2007 | 12:57 AM
MRQ06's Avatar
SQ
Yes sir they did.
Old Jul 15, 2007 | 06:49 AM
not a bad idea
Old Jul 15, 2007 | 10:21 AM
EVOlutionary's Avatar
One thing to check with the brakes is that uneven tire pressures, alignment, or a crowned road can all make the car pull to one side under braking. I would check these first before worrying about replacing the rotors. . .
Congrats on the new car!
EVOlutionary
Old Jul 15, 2007 | 10:47 AM
PurEvo's Avatar
I second that. IF that doesn't go through. I"d say spend a few grand extra and get a brand new IX.
Old Jul 15, 2007 | 08:10 PM
Nuked's Avatar
Originally Posted by MRQ06
Yes sir they did.
Thats right, my bad. I was thinking MR's. Honestly they must be somewhat rare? I can only remember seeing one and that was a dealer in Greensburg, PA.
SQ
