Intermitent oil light
Old Jul 14, 2007, 02:53 PM
byron3636's Avatar
My oil light has been coming on intermittently while idling at stop lights, if i tap the gas while stopped or drive when it turns green the oil light stays off.
I have brand new synthetic oil, and filter. I'm not sure what i should check next... any suggestions?
Old Jul 14, 2007, 02:57 PM
kaftan's Avatar
i would check the oil sensor and wiring to your oil light.
Old Jul 14, 2007, 03:05 PM
byron3636's Avatar
thanks... i haven't don't anything under the hood lately but i'll check those
Redline-Z's Avatar
I imagine you allready did, first check the level if you haven't. If it is fine then I would guess the sensor also. My beater car loses the oil pressure gauge every so often because it was frayed.
Old Jul 14, 2007, 03:17 PM
byron3636's Avatar
yeah level was good, and then i changed oil and filter, and now i'm getting it again.
Old Jul 14, 2007, 03:35 PM
S4STIEVO's Avatar
i had the same problem. mine ended up being the sensor. check for any lose lines as well. thats usaly what it is if not the sensor.
Old Jul 14, 2007, 03:38 PM
byron3636's Avatar
thanks... seems like the consensus is that it's the sensor since i don't seem to have any leaks and the level is all good.
Old Jul 14, 2007, 04:06 PM
3SgteGuru's Avatar
You don't wanna play around when it comes to oil pressure, maybe you might consider just changeing the sender to be sure. But check the wiring first if you haven't already. If the light is still comming on you may have a more severe problem, probably the oil pump.
Old Jul 14, 2007, 04:42 PM
Mellon Racing's Avatar
some brands of filters are less/more restictive than others and oil weights can have an effect.
what brand filter, oil and weight are you running? if it is OEM are you sure it's the right one?
Old Jul 14, 2007, 05:27 PM
Doowop's Avatar
yeah, mine does that too but only did it at the track twice at the end of the day after some hardcore 20mn sessions. It is weird and kinda scary!! Can't wait to add an oil pressure gauge to really see what is going on!! My 9 is less than a year old with 6k on it. I wouldn't think the sensor or wiring would already be faulty but I guess it is possible except it only did it twice and both time what under hard driving conditions.
Old Jul 14, 2007, 08:11 PM
jojipoji's Avatar
the dealership i go to says they stock oil pressure switched because they are NOTORIOUS for failing in the evos and eclipses.
Old Jul 14, 2007, 08:33 PM
kaftan's Avatar
if you have time and really want to you can get tactrix cable and review logs when the light goes on. And you really will have fun watching what is going on in your engine
Old Jul 15, 2007, 09:03 PM
byron3636's Avatar
i actually plan on that, that gives me the excuse to spend the money on the cable. I might also just get an oil pressure gauge along with a new oil sensor.
Old Jul 27, 2007, 05:33 PM
kaftan's Avatar
so, how did it go? cable/sensor/gauge ?
Old Jul 27, 2007, 05:46 PM
awr
awr's Avatar
make sure your car is not just dipping down in idle after a hard drive or prolonged highway driving in hot summer temperatures if this is the problem switching to a 10-40 synthetic will take care of it
