evo scan
Old Jul 20, 2007 | 12:30 PM
kobi2002's Avatar
evo scan
I just downloaded evoscan and it is a good tool to datalog. I did find a problem ir it just could be me. When I log, boost is at 13psi at idle and the tps is at 13% a' i suppose to calibrate somthing
Old Jul 20, 2007 | 01:05 PM
laakness's Avatar
Unless you have installed a JDM MAP sensor you won't be able to read the actual psi.
I believe the TPS reads a positive number since some throttle is needed to keep the car idling.
Old Jul 20, 2007 | 08:22 PM
urslo4n8's Avatar
the tps sensor should show 0% at idle. Like the last post stated BOOST will be inaacurate without whats listed above.
Old Aug 23, 2007 | 09:02 AM
Duh Panda's Avatar
whered you download it?
Old Aug 23, 2007 | 09:03 AM
goosey2099's Avatar
mine also shows close to 13% and thats suppost to be normal
Old Aug 23, 2007 | 09:10 AM
kstpeter33's Avatar
mine always says the TPS is at 12% at idle...
Old Aug 23, 2007 | 09:30 AM
PessimiStick's Avatar
It only shows 0% if you're engine braking at low/medium RPMs. Idle throttle is ~12.x%
Old Aug 23, 2007 | 10:50 AM
zgodfathera's Avatar
so u guys have a laptop running evoscan when driving correct?
Old Aug 23, 2007 | 11:00 AM
Evol.ved's Avatar
Tps should be somewhere between 12 and 14% at ldle.
Old Aug 23, 2007 | 11:03 AM
oh aight thanks a lot..... LMAO
Yes.
