My evo vs friends sti
Old Jul 22, 2007 | 02:48 AM
  #31
EV0lved's Avatar
Originally Posted by HeLLA JDM y0
Old Jul 22, 2007 | 03:10 AM
  #32
Jakeg97's Avatar
it might be close , but i think your friends sti would win
Old Jul 22, 2007 | 08:56 AM
  #33
STi300whp's Avatar
Okay, guys.... you wanna know a real world outcome of what happens when you race these two cars?
I have an 05 Stage 2 STi and I raced a tuned Evo IX with MBC, Reflash, fuel pump, drop in filter, and turboback in the Evo.
First Run: 60-110mph I lost by 1 full car and was reeling him after 110mph.
Second run: This time my passenger got into a different car and we went from 50-125mph. From the get go the Evo 9 pulled and then by 120mph I caught up and lost by 1/2 a car. As the speeds went higher my STi did a lot better. Once I get my new tune I think it'll be neck to neck.
Old Jul 22, 2007 | 09:32 AM
  #34
DSMEVOLUTION's Avatar
Didn't you already state this earlier?
Old Jul 22, 2007 | 09:44 AM
  #35
IXmr321's Avatar
lol +1
Old Jul 22, 2007 | 09:47 AM
  #36
thereasonsf3's Avatar
lol!!
Btw cobb stages are very conservative. Your sti friend should just get an bigger IC, IC hoses, and get a tune and should be well over the 300whp mark.
Old Jul 22, 2007 | 12:36 PM
  #37
brkn4g63's Avatar
I drove both through a road course. Stock and stock. Drove the evo, stopped, unfastened the seat belt, walked over to the STi, buckled up and went again. You, on the other hand, claim I am talking out of my ***. And direct me to someone else's review. Good call!
I highly, HIGHLY doubt that you even driven an EVO or an STi let alone own one.
Old Jul 22, 2007 | 12:44 PM
  #38
MRTXEVO's Avatar
good luck
with ure mods and his, the cobb ap will probably get him around 350 or so. I just test drove a sti with downpipe, full exhaust, cold air and ap it was faster than the evo with the mods you said you have installed. it will be close though. i ultimately think it will come down to the driver. if you raise your boost like someone mentioned on here than u might take him. remember that sti stock runs boost level at like 14.5 and evo at 20 i think. if he raises his then you might lose. good luck and go evo.
  #39
AtO-MiX's Avatar
Ok but you still lost soo what does it really matter.
Old Jul 22, 2007 | 03:03 PM
  #40
W0459732's Avatar
i had an 06 sti, i traded it for the 9 mr. I drive my buddies stock 06 sti and he drives my stock 9 mr and i loose 2 out of 3 times, i drive my evo and i win 2 out of 3 times.
go figures
Old Jul 22, 2007 | 03:09 PM
  #41
HeLLA JDM y0's Avatar
Again, quit talking out of your ***.
Old Jul 22, 2007 | 03:10 PM
  #42
JGC's Avatar
JGC
Originally Posted by mcwop23
Stis put down power on the dyno but it doesn't really translate at the track
That's very funny
<--- Sti with less than 500WHP running 10's on a bolt-on Turbo.
Old Jul 22, 2007 | 03:49 PM
  #43
Mr. Evo IX's Avatar
It's all speculation. Let's hear the outcome if you do race. And do it at the track instead of the street.
btw.. I'm sure a Cobb Stage 2 map increases the boost on the STI. I run a OSECUROMS stage 1 map on my STI and it's got raised boost.
Also, You really cant compare the 2 boost levels as the Evo having an "advantage" because it runs more boost from the factory. Evo comes with 19+ psi peak boost stock and can run 23 psi peak on 93 octane with a good tune. Generally STI's dont like that much boost on stock gear since they have a smaller turbo, stock they run 14.5 and generally you add about 4psi to that for 18.5psi. I've seen some 23 psi Subaru maps but that seems a little scary with a stock turbo. So adding 4psi to each would be considered equal. Stage 2 boost controlling STi maps generally have about 18-19psi.
Old Jul 22, 2007 | 04:26 PM
  #44
EvoFlash's Avatar
Your turbo is bigger but copp is a tune he will have that on you.
Old Jul 22, 2007 | 05:37 PM
  #45
mrdevo's Avatar
He has the 5 speed right?
