Twin Scroll; Making all Existing Turbo Kits Obsolete?
You guys are forgetting the torque spike that will be presentwith a Stock turbo and absent especially on a turbo as large as the 40R. You will not have 100% stock like spoolup, I mean a Modded IX is fully spooled MUCH MUCH faster then 3500, don't forget, many people get them into the 2900's or less.
Comparing to a 100% STOCK Evo, well Buschur overlayed his 35R kit against a stock VIII and it was better all around even with the lag, THAT was amazing
That is a good point, but I doubt it has much to do with the increase in spoolup. The rod/stroke ratio with the 4G64 (versus using a stroked 2.3L 4G63) is much better, and there will be less losses associated with the piston side-loading. You have to realize that an increase of .4L of displacement is HUGE. Thats like having another piston in the engine (almost equivalent to the volume of another combustion chamber), mivec also helps the spool along. A good example is the setup Vigo posted above, a brian crower stroked 2.4L 4G63. The rod/stroke ratio is horrible, yet the GT35 is outputting full pressure by 3500 rpms. Having a awesome r/s ratio in a 2.4L 4G64 is just icing on the cake, and will allow for much higher revs, even though it probably won't need to rev high because it can spool up the turbo so quickly
What do you mean by full pressure? 20PSI?
wrong. You are forgetting that a 2.4 4G64 is an entirely different block that has a taller deck height.
Here the link to the Evo 7 with a 2.4 liter stroker and AMS GT35R kit. Scroll down to look at the graph.
https://www.evolutionm.net/forums/sh...ighlight=graph
If you notice on a "stroker" piston, the wrist pin is higher towards the top of the piston than on a stock 4g63 piston. This is the reason that stroker pistons are not interchangeable with stock pistons unless you increase the length of the rod.
You mean the deck height that is made up by moving the wrist pin up on the piston?
You have two options with the 4G64, use the same ol 4G63 150mm rod, or a 162mm rod in combination with the 4G63 stroker piston (available from magnus or other machine shops). Given the choice I'd always use the long rod 4G64, as many have already done. This way you get .4L of displacement and a better r/s ratio than the 2.3L 4G63 stroker setup.
That would be a waste of some extra deck height! =)
However, you want to use the 156mm rod not the 162mm with the 2.4 unless you want your pistons to stick out the top of the block. The 162mm rod is usually used to create a 2.1L long rod motor.
Plenty of people have used the 162mm long rods in their 4G64's, although I am not sure which pistons they used, I was told that the pistons were 4g63 stroker pistons, but I'm not entirely sure that is correct. If you interested, call magnus, they've done it.
