Twin Scroll; Making all Existing Turbo Kits Obsolete?
High_PSI, a properly designed intake manifold should not sacrifice midrange power. If anything, it will help spool-up. The AMS intake is probably the best one out for the EVO right now. If you do some research, you will see that a properly designed intake manifold can HELP spool-up, while at the same time providing huge top-end gains. My 2 cents.
~fred
~fred
~fred
~fred
l8r)
This is a very generalized statement, you can't just say you will lose 100-200 rpm in spoolup. It depends on the turbo and it depends on the engine configuration (2.0, 2.1, 2.3, 2.4). Maybe with you will loose some spoolup with some puny stock 16g based turbo, but with larger turbos that require high flow, its very necessary to have a high flowing intake tract.
Ludi has a AMS 50Trim Kit I believe, or a 3071, and went from not having to having a AMS VSR intake manifold, he knows exactly what he is talking about and you are wrong. An intake manifold that flows more air than a stock one at any RPM level will almost always take longer to spool than a smaller/more restrictive one.
Scorke
Go out in your car and tell me when you get 22 psi in 1st and second gear, I bet it is MUCH later......
Scorke
Will check back after lunch to verify. I just know first gear is done so fast I prob won't be able to tell. I need that stupid tactrix cable for logging.
l8r)
~fred
~fred
From what i understand the goal of twin scroll header design is to have (in a 4-cylinder example) the 2 cylinders which will exhaust at the same time on the same inlet of the twin scroll housing so that no intake/exhaust interference between cylinders occures, so your getting alternating exhaust pulses between to two inlets, which are infact 2 of the cylinders pulses combined more or less. I could be way off but thats what i gather, equal length is not the goal at all.
HAHAHAHAAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAAHAHAHA HAHAHAHAAHAHAH
just stating facts and not arguing
