need help asap
Old Jul 24, 2007 | 09:36 PM
itzcharlez's Avatar
need help asap
ok guys.. i was installing my defi's and everything went well... untill i forgot that the 12v constant line wasnt wrapped up.... and the battery was still connected.... so as i start to put the wires behind the panel away from visable sight it touched the open ground (metal bolts.. etc) sparked and now when i turn the key i get nothing.. radio dosnt work.. clock.. basically anything connected to a constant 12v... the engine dosnt even crank... anyone have anyidea how to fix this?
Old Jul 24, 2007 | 09:49 PM
jhanksevo's Avatar
did u check ur fuses under hood and in car
CRX2EVO's Avatar
check your fuses
Old Jul 24, 2007 | 09:52 PM
Ivan@AMS's Avatar
Have you inspected the fuses under the hood yet? Most likely where the issue is. Without a wire schematic, I cant really tell you which fuse to look at.
rocket_man's Avatar
check your fuses
Old Jul 24, 2007 | 09:57 PM
STOCK_EVOLUTION's Avatar
+1 ^^
Old Jul 24, 2007 | 10:04 PM
itzcharlez's Avatar
could it be the relays though?
itzcharlez's Avatar
cause when i turn the key... it dosnt even crank..
i touched from ignition hot to an open ground...
Old Jul 25, 2007 | 11:52 AM
joey0480's Avatar
fuse should have blown...pop
Old Jul 25, 2007 | 12:00 PM
kimletrim's Avatar
Registered User
Hold your horses...don't blow a fuse!
