Clutch job - help needed - ??'s
Old Jun 29, 2003 | 07:33 AM
Alfriedesq's Avatar
I am R & R'ing my clutch on the Evo Viii
The online shop manual talks about pulling the "output shaft" - a shaft that appears to go through the transaxel - into the transfer case - its a shaft that the driver's side halff shaft snaps onto
The manual says you need some special slide hammer to pull the shaft out of the trans
My question is if anyone else has done the clutch job and IF you have to pull thats shaft out becuase I have been wacking away fairly good at that shaft with a tool i made up and it dosn;t seem to want to come out
Old Jun 29, 2003 | 11:10 AM
Alfriedesq's Avatar
Thanks for all the help - fellow evo owners !
I wound up getting a el cheapo dent puller - then I tapped on some 8 mm threads to the end
Presto bango and out teh shaft came
Now I have the transfer cash half way out and am waiting to round up some crew to help me to move the enging down and forward enough to drop out the transfer case
My only consolation in all of this is at least this car is almost new and very clean
I would hate doing this nightmare job on an old rusty and dirty heap thats been in the snow for s few years
Old Jun 29, 2003 | 11:21 AM
Kinmar_X's Avatar
clutch finally went eh?
or are you just upgrading?
Old Jun 29, 2003 | 11:30 AM
2Cool's Avatar
You're on unknown ground, Al. I sat and watched Friday as an experienced DSM AWD mechanic try for 4 hours to remove the transfer case on my car, no dice. That despite repeated calls to consult with the local Mitsu dealer mechanics. hopefully he will figure it out on Monday, and likely they regret giving me a set price rather than hourly rate.
So take pics, write up a good how-to, as lots of us are going to need it.
Old Jun 29, 2003 | 05:37 PM
Alfriedesq's Avatar
We got it out after doing thye following :
1 - made a custom slide hammer "output shaft" remover - I took an off the shelf dent puller and grafted some 8 mm threads onto the end of it with a die - - with that the shaft poped right out of the driver's side of the tranny
2 - there are a total of 6 bolts holding the tranfer case - the last one is kind of hiding up in there
3 - you have to remove ALL the motor mounts and move the engine all the way up to the front as far as you can and also lower the front of the motor down as far as you can
Once you do that - the transfer case can be slid, twisted and contorted up over the power steering lines and out through the small gap between the sub-frame and the engine
The real fun I think will be putting it back into place - the splines are very strange and it can only go in one way
A flat rate deal on this job is a great deal for the customer
Its a long job and not one that is a lot of fun
The only good news so far - for those who are sticking with the stock set up - - we have a very light weight stock flywheel
Old Jun 29, 2003 | 05:42 PM
Shahul X's Avatar
wow, and i thought this was gonna be hard..... ....man...
-Shahul
Old Jun 29, 2003 | 08:15 PM
Jonasan50's Avatar
Why didn't you just drop that sub-frame? From the looks of it, that would be much easier.. But as we all have heard, looks can be decieving...!!
Old Jun 30, 2003 | 05:05 PM
2Cool's Avatar
The shafts into the transaxle were the issue. The mechanic was used to older DSMs and Subies, where the axles have a female splined end to go over the output shafts, and the shafts stay in the tranny when removing. Once he figured it out he used a puller to yank them out, and it was cake from that point.
Love the Exedy single disk so far. Grabs like heck, but can still slip it for high RPM launches. Actually has a bit lighter pedal feel than stock too.
Old Jul 1, 2003 | 03:28 PM
Kazoo's1st Evo8's Avatar
how much and where for the exedy clutch?
Old Jul 1, 2003 | 04:40 PM
2Cool's Avatar
Got it over at Z-1 Performance for about a $100 less than what they list on the site. Call Adam up, he worked hard to make sure I got the part quick.
Old Mar 26, 2004 | 05:44 AM
evo4mad's Avatar
on my EVO4 I have removed:
-propeller drive shaft
-left cv from gearbox
-right cv from transfer case
-bolts from transfer case
the transfer case should slide off to the right, but seems to be taking the left output shaft with it and getting stuck after moving it 2cm to the right.
I have already applied a lot of pressure in both directions, I am happy to apply huge pressure, just not in the wrong place or direction.
thanks you answered my question, I will go and find a puller to get that sucker out.
Old Mar 26, 2004 | 05:56 AM
sr20det91's Avatar
Great innovation on the shaft removal tool. I've been ramping up to do a clutch job myself, and you just solved my biggest concern. Nice work.
As others have said, removal of the sub frame seems to be the way to go from others who have tackled this job. My be a bit more work, but I think it would be worth it to not have to move the motor around so much and risk busting PS lines or worse. Keep us updated on any more issues you may run into.
EVOWRC111
15
Oct 15, 2012 06:36 PM
DevnBlakley
Lancer How Tos / Installations
Jul 21, 2012 08:02 AM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
evo585
11
Jul 29, 2009 12:55 PM
dryad001
Aug 15, 2008 05:00 PM
