Clutch issue.... maybe?
not holding boost means that higher hp clutch is not holding and starts to spin. Meaning that the disk is just spinning and not grabbing on the flywheel. If it revs up in higher gear when you wot/ higher boost then the clutch is gone. Be careful with that because if you get it to hot than the spring in the pressure plate can break and cause some damage. Had this happen in a 2g talon.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
tequila357
Feb 18, 2016 11:42 AM
