OBD2 pinout
Old Aug 6, 2007 | 02:58 PM
Lazeum's Avatar
OBD2 pinout
I'm looking for the obd2 pinout info (as the title states).
I was able to find info on the obd2 norm but most of the pins are defined by the manufacturer... I found nothing about Mitsu
http://en.wikipedia.org/wiki/On_Board_Diagnostics
I'm looking for the rpm signal, can someone help me???
Old Aug 6, 2007 | 03:06 PM
Speed Corps's Avatar
Former Vendor
Go to Evomoto.com and go to the tech section, installations, then electronics. It's right there!
Old Aug 6, 2007 | 03:17 PM
Lazeum's Avatar
Thanks for your answer pin 58 for the ECU.
I was more looking for the pin on the OBD plug which is easier to access. (my goal is to access rpm signal, to record it and get dyno curves )
In the mean time, I found something regarding Mercedes which seems to use the same norm (ISO 9141). rpm should be pin #3 on the OBD plug...
http://www.mbclub.co.uk/forums/showthread.php?t=13339
Bobi
Jun 16, 2016 11:17 AM
mrfred
Oct 8, 2014 05:07 PM
mrfred
May 13, 2009 03:53 PM
Keepster13
Sep 12, 2008 11:54 PM
HobieKopek
Lancer Engine Tech
47
Apr 7, 2004 01:06 PM
