Hole in Upper IC pipe
Old Aug 6, 2007 | 11:57 PM
negativeB's Avatar
I just noticed(granted, I didn't open my hood in a long time) that I have a hole in my upper IC pipe. It was caused by rubbing against the hood vent. Anyone else have this problem? I've never touched the upper IC pipe but it does seem elevated.
Anyway, I'm looking for a temporary fix until I decide to replace it or upgrade. And anyone have any suggestions on an upgrade? Thanks.
BTW, I usually boost just under 1.4bars and now peak at 1.3 and hold around 1.2.
Old Aug 7, 2007 | 12:00 AM
W_evo8's Avatar
stock piping? if its rubbing something caused it to hit against that I'd check all your piping to make sure nothing moved out of place. In the mean time you could remove the hood vent fins to get a little extra clearance and prevent further damage.
Old Aug 7, 2007 | 09:28 AM
althemean's Avatar
do you have an intake on the car? sometimes those can cause the pipe to shift position.
Just take the pipe to an aluminum welder and have the hole filled for a temp fix (probably be fine for a permanent repair)
A real temp fix is to get some sort of crappy tubing from the auto zone "street racer" section and wrap the pipe (where ever your hole is) and put two hose clamps to hold it down. I would use some silicone to seal the repair material on then clamp it down. Be sure to let it cure for an hour or two before driving so the boost press doesnt blow the silicone out.
Old Aug 7, 2007 | 09:30 AM
Sky Evo X's Avatar
Or you could upgrade to an aftermarket system. Injen, fujita, and greddy
all have UICP upgrades.
Old Aug 7, 2007 | 04:07 PM
KenMasters's Avatar
+1---Take it to a welder. Or upgrade. Either way it's gonna cost you $.
Old Aug 7, 2007 | 04:12 PM
HaVoK23's Avatar
JB Weld FTMFW!!!! hahaha
Old Aug 7, 2007 | 04:16 PM
IEXCELR8's Avatar
Here is a few for sale
https://www.evolutionm.net/forums/sh...=284545&page=2
https://www.evolutionm.net/forums/sh...highlight=UICP
https://secure.buschurracing.com/cat...064fe9784a464c
Old Aug 7, 2007 | 04:17 PM
JDMCT9MR's Avatar
Jb Weld Is Your Best Friend For A Quick Fix That Lasts!
Old Aug 9, 2007 | 12:22 AM
negativeB's Avatar
where can i buy jb weld?
Old Aug 9, 2007 | 12:28 AM
Bonestock!'s Avatar
You cant be serious...
Old Aug 9, 2007 | 12:32 AM
negativeB's Avatar
I was. I checked their website but realized I clicked the vendor section, which said I can buy it in Nevada. =j Anyway, I looked again and got it. Thanks.
Old Aug 9, 2007 | 11:13 AM
assaultman2004's Avatar
Autozone, Pep Boys,...etc.
jdubson1
Dec 10, 2011 06:48 PM
evo_8_u
Midwest Region
May 9, 2008 11:04 AM
bboy_RES
28
Aug 12, 2007 11:23 AM
gaulrich2003
Feb 16, 2006 09:13 AM
xstang
May 28, 2004 08:26 AM
