Shifter hard to move left and right
Old Aug 9, 2007 | 01:57 PM
gohandbz88's Avatar
Has anyone had this issue before with the shifter being very hard to move left and right? It's almost as if it seized up. All we did was spray some WD-40 on the shifter bushings in the engine bay and the problem was resolved. Any idea as to why this would happen?
Old Aug 9, 2007 | 02:56 PM
Segfault's Avatar
I had that happen a little bit when I first bought my Evo, but it went away as I put more miles on it. Might just be a little stiffness that you have to work out through usage.
Old Aug 9, 2007 | 03:31 PM
awr's Avatar
awr
hmm wd 40 is not a lube its name stands for water displacement recipe #40 make sure to go back in there with a lubricant
Old Aug 9, 2007 | 03:33 PM
orugacoja's Avatar
wowowow thats happening right now with my shift
Old Aug 9, 2007 | 04:04 PM
JDMCT9MR's Avatar
Thats a bunch of junk!Hopefully I don't run into that.
Old Aug 9, 2007 | 04:42 PM
rcheung's Avatar
Ususally this happens when the shifter cable gets stuck on the bushing. If you get some poly bushing and grease the heck of them, it may solve your problem.
Old Aug 10, 2007 | 06:52 AM
gohandbz88's Avatar
For the time being, I haven't seen anymore issues after spraying it with wd40. If the problem does resurface, I'll put plenty of grease on it.
Old Aug 10, 2007 | 10:38 AM
evo_8_u's Avatar
mine did the same thing after I put in metal shifter bushings!
I put in a ton of grease inside that rubber boot by the trans an it fixed the problem.
Old Aug 10, 2007 | 06:08 PM
03silevo's Avatar
just make sure the shifter bushing underneath the hood is sitting flush inside the cables never have put any grease on mine and there working fine.......the zaklee ones that is
Old Aug 10, 2007 | 06:41 PM
Maxdelta's Avatar
Mine is also do it that. Its like the cluch isnt grinding or anything its just not smooth shift. I dont feel it in the drive or in the peddles jsut the shifter alone i will also try grease cause it does feel like metal on metal and no lube
Old Aug 10, 2007 | 10:48 PM
EVO9_IX's Avatar
all evos have that ****
JTCB
Jan 14, 2016 01:23 PM
xmaster19
11
Jan 3, 2016 08:35 PM
LakerRaider
34
Jul 16, 2011 08:05 PM
toddcfii
Jul 29, 2007 07:42 AM
tke_413
25
Jan 7, 2007 08:23 PM
