is this a boost leak or do i need a new tune?
Old Aug 12, 2007 | 10:08 AM
filter's Avatar
first some info.
ok i moved from watertown ny (elevation aporx 500ft) to rapid city SD (elevation aporx 3300) my car was shipped since getting here the car seem to be actting wierd some days other days its fine.
i never really got on the car since getting here. once i got the car i installed my ams intercooler and ams licp and my buscur Uicp.
since installation of these i hit 23psi (depending on the heat i may hit 24-25psi then i have adjust my MBC) but it drops dramastically towards redline. getting down in 16psi range. before installiong of these and before the car was moved out here i would hold 23-22 all the way to redline. and some days i cant hit full boost in 1st gear.
would this be caused becasue of a boost leak? or is the elevation that drastically changed where i need to get retuned? im running 94 octane.
Old Aug 12, 2007 | 10:14 AM
Warrtalon's Avatar
Altitude reduces the efficiency of the turbo, thus causing more severe boost taper. You also NEVER held 22-23psi to redline. YOu may have held it to 5000rpm, but it certainly tapered 2-3 psi by redline. You never can hit full boost in 1st gear, because there isn't enough load.
Yes, you also need a retune for altitude.
Old Aug 12, 2007 | 10:21 AM
filter's Avatar
since im north of you any good tuners in this area? so should i cross out the boost leak problem?
Old Aug 12, 2007 | 10:23 AM
Warrtalon's Avatar
Actually, yes, you are relatively close. Join up at RMEVO.com, and we can help you out. Our local tuner is in Cheyenne, which is even closer to you than most of us, so that should work out nicely. Is it really only 3300' up there? It's over 6000' down here...
Old Aug 12, 2007 | 11:00 AM
chrismnj's Avatar
when do u actually need to retune your car ? besides new mods .
Old Aug 12, 2007 | 12:54 PM
Dapper Dan's Avatar
differnt seasons............if you tune your car in 100 degree heat in the summer and expect it to run the same in 40 degree whether you would be wrong.....
Old Aug 12, 2007 | 01:46 PM
Whoop_ass's Avatar
yip i have to agree with War!!
Altitude is a killer and makes our turbos work harder.
people always say they make X amount of boost at 7k rpm!
but until it is logged i am no believer.
i am at 5300ft and i taper to 1.15 bar at 7k rpm with and EVC 6 mapped correctly.
I am gonna try an Actuator soon to see if i can hold more boost towards redline.
Old Aug 12, 2007 | 03:06 PM
filter's Avatar
this is the first time the car has seen anything higher then 800ft in elevation. so going from 500ft or so to 3300 i was wondering how much of a difference that had on the car and i didnt know if a boost leak could cause what im having since i changed parts before i really even drove the car around here.
Old Aug 12, 2007 | 05:29 PM
mikesevo8's Avatar
Sorry to go OT a bit, but here's a log of one of my runs last week. Logged with my UTEC. Ran 4th out to redline.
I don't have a problem holding good boost up top. There's still some taper.
I still have 2 boost leaks to fix - TB seals and a small leak on the LICP.
Code:
       EXT           Load Knock                Mod   Mod          Mod
 RPM   MAP   MAF TPS Site Count  Ign#1  Inj#1  Ign   Fuel Boost   MAF
       psia   Hz  %               deg   duty   deg    %   (OL)     Hz
  899  -6.4   32   0  00    00   +11.4    1.6 ECU.   +0.0 ECU.     32
  891  -6.6   32   0  00    00   +17.8    1.7 ECU.   +0.0 ECU.     33
  868  -6.9   32   0  00    00   +16.7    1.5 ECU.   +0.0 ECU.     32
  853  -6.9   32   0  00    00   +12.5    1.7 ECU.   +0.0 ECU.     32
  958  -6.4  125  18  00    00   +15.2    7.5 ECU.   +0.0 ECU.    145
 1740  -4.7  168  93  10    00   +20.3    5.4 ECU.   +0.0  75.00  166
 2858  -3.1  303 100  10    00   +21.8   10.8 ECU.   +0.0  75.00  430
 4100  -1.4  502 100  10    00   +24.1   20.0 ECU.   +0.0  75.00  555
 5411  +0.0  786 100  10    00   +22.8   25.8 ECU.   +0.0  75.00  919
 6027  +0.9  924 100  10    00   +21.3   28.8 ECU.   +0.0 LCM.    939
 5952  +2.1  912 100  20    00   +22.0   27.2 ECU.   +0.0 LCM.   1004
 6060  +3.3  932 100  20    00   +22.2   28.7 ECU.   +0.0 LCM.   1004
 5941  +4.5  899  79  20    00   +22.4   28.2 ECU.   +0.0  75.00  841
 6027  +4.2  507  30  00    00   +30.0   19.1 ECU.   +0.0 LCM.    474
 6116  +3.0  897  51  10    00   +27.5   29.2 ECU.   +0.0 LCM.    871
 5973  +2.3  542  32  00    00   +30.3   18.6 ECU.   +0.0 LCM.    412
 5827  -0.5  169  12  00    00   +38.4   17.6 ECU.   +0.0 ECU.    204
 5464  -3.6   92  12  00    00   +38.2    7.3 ECU.   +0.0 ECU.     60
 5020  -6.4   90  11  00    00   +38.1   71.7 ECU.   +0.0 ECU.    190
 5257  -9.2  473  29  00    00   +32.1   18.3 ECU.   +0.0 ECU.    572
 6038  -8.5  616  33  00    00   +31.3   27.9 ECU.   +0.0 LCM.    446
 5640  -7.6  143  16  00    00   +38.4    7.2 ECU.   +0.0 ECU.    170
 5837  -6.4  713  39  10    00   +29.1   25.5 ECU.   +0.0 ECU.    733
 5878  -5.2  241  20  00    00   +36.3    9.8 ECU.   +0.0 ECU.    213
 5473  -6.6  252  21  00    00   +37.1   10.1 ECU.   +0.0 ECU.    251
 5402  -7.1  142  16  00    00   +38.4    8.9 ECU.   +0.0 ECU.    176
 5537  -7.3  635  37  10    00   +30.3   23.8 ECU.   +0.0 ECU.    694
 5889  -7.3  250  20  00    00   +35.2   11.0 ECU.   +0.0 ECU.    219
 5611  -7.6  228  20  00    00   +38.3   58.5 ECU.   +0.0 ECU.    333
 6071  -6.4  645  39  10    00   +29.1   18.6 ECU.   +0.0 LCM.    528
 5668  -5.9  173  18  00    00   +38.3   10.8 ECU.   +0.0 ECU.    205
 5668  -7.1  412  26  00    00   +33.3  ---.- ECU.   +0.0 ECU.    542
 5952  -5.7  351  25  00    00   +31.4   10.6 ECU.   +0.0 ECU.    212
 5455  -6.9  131  15  00    00   +38.3    8.3 ECU.   +0.0 ECU.    144
 5583  -7.3  597  34  00    00   +30.0   24.3 ECU.   +0.0 ECU.    609
 5931  -6.2  167  15  00    00   +37.3    8.6 ECU.   +0.0 ECU.     82
 5564  -7.8  260  22  00    00   +38.3    9.7 ECU.   +0.0 ECU.    367
 5491  -7.8  502  27  00    00   +33.3   31.1 ECU.   +0.0 ECU.    651
Start run
1st
 5659  -6.2  891  58  10    00   +25.4   24.0 ECU.   +0.0  75.00  957
 5518  -3.8 1225 100  10    00   +14.5   40.2 ECU.   +0.0  75.00 1396
 4975  +1.6 1533 100  30    00    +9.0   49.6 ECU.   +0.0  75.00 1428
 4268  +8.7 1336 100  50    00    +8.1   48.9 ECU.   +0.0  75.00 1488
 4426 +14.8 1340 100  70    00    +8.0   48.5 ECU.   +0.0  75.00 1533
 4694 +20.0 1543 100  80    00    +8.1   53.7 ECU.   +0.0  75.00 1453
 4866 +23.6 1582 100  80    00    +8.9   23.5 ECU.   +0.0  75.00 1533
 5167 +25.0 1597 100  80    00    +8.1   55.2 ECU.   +0.0  75.00 1798
 5952 +25.5 1923 100  80    00   +11.0   63.8 ECU.   +0.0  75.00 1838
 6613 +25.2 1984 100  80    00   +13.7   64.5 ECU.   +0.0  75.00 2049
 7199 +24.8 2083 100  80    00   +15.8   66.4 ECU.   +0.0 LCM.   1968
2nd
 6172 +23.1 1050 100  70    00   +23.3   31.5 ECU.   +0.0 LCM.   1126
 5192 +19.8 1070 100  50    00   +17.2   33.9 ECU.   +0.0  75.00 1219
 5574 +17.2 1694 100  40    00   +10.1   54.4 ECU.   +0.0  75.00 1824
 5698 +16.7 1886 100  60    00    +9.1   68.4 ECU.   +0.0  75.00 2032
 5878 +18.1 1872 100  80    00   +10.2   66.6 ECU.   +0.0  75.00 1736
 6138 +21.5 1953 100  80    00   +11.2   65.5 ECU.   +0.0  75.00 1908
 6459 +24.3 2000 100  80    00   +12.3   68.3 ECU.   +0.0  75.00 2016
 6816 +24.8 2032 100  80    00   +13.9   69.4 ECU.   +0.0  75.00 1984
 7092 +24.3 2057 100  80    00   +15.5   65.9 ECU.   +0.0  75.00 1953
 6587 +24.0 1291 100  80    00   +15.8   54.1 ECU.   +0.0 LCM.   1046
3rd
 6071 +21.7 1123 100  60    00   +22.1   35.0 ECU.   +0.0 LCM.   1308
 5668 +19.1 1672 100  50    00   +11.1   56.2 ECU.   +0.0  75.00 1811
 5640 +18.6 1908 100  60    00    +9.3   65.8 ECU.   +0.0  75.00 1811
 5717 +19.1 1824 100  80    00   +10.2   63.6 ECU.   +0.0  75.00 1865
 5868 +21.5 1886 100  80    00   +10.3   63.5 ECU.   +0.0  75.00 1736
 6060 +24.5 1937 100  80    00   +11.3   69.2 ECU.   +0.0  75.00 1923
 6242 +25.5 1960 100  80    00   +11.2   67.1 ECU.   +0.0  75.00 1984
 6385 +25.2 1992 100  80    00   +12.5   69.9 ECU.   +0.0  75.00 2016
 6548 +25.0 2000 100  80    00   +12.5   68.4 ECU.   +0.0  75.00 2000
 6706 +24.8 2008 100  80    00   +13.6   71.6 ECU.   +0.0  75.00 2136
 6844 +24.5 2024 100  80    00   +14.7   68.8 ECU.   +0.0  75.00 2100
 7002 +24.5 2066 100  80    00   +15.8   68.5 ECU.   +0.0  75.00 2118
 7168 +24.3 2066 100  80    00   +16.0   71.9 ECU.   +0.0  75.00 2083
 7309 +24.0 2074 100  80    00   +16.5   71.3 ECU.   +0.0  75.00 2118
 7440 +23.8 2083 100  80    00   +16.7   68.0 ECU.   +0.0  75.00 2100
 6706 +23.1 1207 100  70    00   +23.6   43.7 ECU.   +0.0 LCM.   1068
4th
 5359 +20.5 1004 100  60    00   +19.9   31.9 ECU.   +0.0  75.00 1262
 5437 +18.4 1730 100  50    00    +8.7   60.0 ECU.   +0.0  75.00 1838
 5659 +18.4 1901 100  60    00    +9.1   65.7 ECU.   +0.0  75.00 1712
 5659 +19.3 1798 100  80    00   +10.1   62.3 ECU.   +0.0  75.00 1851
 5787 +22.6 1872 100  80    00   +10.3   63.9 ECU.   +0.0  75.00 1798
 5878 +25.2 1838 100  80    00   +10.2   66.2 ECU.   +0.0  75.00 1937
 5952 +25.7 1865 100  80    00   +11.5   64.1 ECU.   +0.0  75.00 1811
 6027 +25.7 1865 100  80    00   +11.1   67.2 ECU.   +0.0  75.00 1798
 6138 +25.2 1930 100  80    00   +11.4   69.0 ECU.   +0.0  75.00 2100
 6207 +25.2 1953 100  80    00   +11.2   68.4 ECU.   +0.0  75.00 1937
 6277 +25.2 1945 100  80    00   +11.7   70.3 ECU.   +0.0  75.00 1984
 6373 +25.2 1968 100  80    00   +12.1   68.3 ECU.   +0.0  75.00 1968
 6447 +25.2 1960 100  80    00   +12.1   67.8 ECU.   +0.0  75.00 1851
 6497 +25.2 2000 100  80    00   +12.1   69.7 ECU.   +0.0  75.00 2066
 6613 +25.2 2024 100  80    00   +13.1   69.8 ECU.   +0.0  75.00 1937
 6680 +25.0 2000 100  80    00   +13.7   72.9 ECU.   +0.0  75.00 1953
 6734 +24.8 2008 100  80    00   +13.6   70.3 ECU.   +0.0  75.00 2100
 6816 +24.8 2040 100  80    00   +14.7   71.6 ECU.   +0.0  75.00 1953
 6887 +24.5 2040 100  80    00   +14.7   68.5 ECU.   +0.0  75.00 2000
 6958 +24.5 2057 100  80    00   +16.2   69.6 ECU.   +0.0  75.00 1953
 7032 +24.3 2057 100  80    00   +16.6   66.8 ECU.   +0.0  75.00 2032
 7092 +24.3 2049 100  80    00   +16.5   70.0 ECU.   +0.0  75.00 2232
 7153 +24.0 2066 100  80    00   +16.6   71.7 ECU.   +0.0  75.00 2066
 7215 +23.8 2083 100  80    00   +16.5   68.6 ECU.   +0.0  75.00 2066
 7278 +23.8 2083 100  80    00   +17.5   69.0 ECU.   +0.0  75.00 2049
 7342 +23.8 2083 100  80    00   +17.4   71.0 ECU.   +0.0  75.00 2192
 7440 +23.8 2118 100  80    00   +17.7   69.9 ECU.   +0.0  75.00 2083
 7457 +23.6 2092 100  80    00   +17.6   72.0 ECU.   +0.0  75.00 2016
 7507 +23.6 2109 100  80    00   +17.7   67.9 ECU.   +0.0  75.00 2136
 7575 +23.6 2092 100  80    00   +17.7   68.9 ECU.   +0.0  75.00 2100
 7680 +23.6 2118 100  80    00   +17.8   70.3 ECU.   +0.0  75.00 2232
 7698 +23.6 2092 100  80    00   +17.7   73.1 ECU.   +0.0  75.00 2066
 7716 +23.6 2136 100  80    00   +17.6   69.4 ECU.   +0.0  75.00 2173
 7806 +23.3 1547 100  80    00   +17.8   10.4 ECU.   +0.0  75.00 1533
Run over
 7716 +19.1  197   2  00    00   +38.8    9.9 ECU.   +0.0 ECU.     54
 7593 +10.8   92   0  00    00   +38.9   10.6 ECU.   +0.0 ECU.    132
 7490  +1.9  104   0  00    00   +38.7    9.9 ECU.   +0.0 ECU.    119
 7407  -7.1   75   0  00    00   +28.8    6.0 ECU.   +0.0 ECU.     79
 7309 -11.8   60   0  00    00   +28.8    6.0 ECU.   +0.0 ECU.     52
 7168 -13.0   62   0  00    00   +28.9    6.0 ECU.   +0.0 ECU.    124
 7092 -13.0   55   0  00    00   +28.8    6.0 ECU.   +0.0 ECU.     62
 6973 -13.0   74   0  00    00   +28.8    6.0 ECU.   +0.0 ECU.     79
 6872 -13.0   78   0  00    00   +28.8    6.0 ECU.   +0.0 ECU.     67
 6802 -13.0   78   0  00    00   +28.7    6.0 ECU.   +0.0 ECU.     88
 6680 -13.0   75   0  00    00   +28.6    6.0 ECU.   +0.0 ECU.     84
 6561 -13.0   75   0  00    00   +28.9    6.0 ECU.   +0.0 ECU.     76
 6459 -13.0   74   0  00    00   +28.7    6.0 ECU.   +0.0 ECU.     77
 6385 -13.0   75   0  00    00   +28.5    6.0 ECU.   +0.0 ECU.     76
 6230 -13.0   73   0  00    00   +28.5    6.0 ECU.   +0.0 ECU.     76
 6127 -12.8   75   0  00    00   +28.6    6.0 ECU.   +0.0 ECU.     72
 5973 -12.8   74   0  00    00   +28.5    6.0 ECU.   +0.0 ECU.     69
 5847 -12.8   73   0  00    00   +28.5    6.0 ECU.   +0.0 ECU.     73
 5727 -12.8   73   0  00    00   +28.4    6.0 ECU.   +0.0 ECU.     75
 5592 -12.8   74   0  00    00   +28.5    6.0 ECU.   +0.0 ECU.     76
 5446 -12.5   73   0  00    00   +28.4    6.0 ECU.   +0.0 ECU.     70
 5307 -12.5   72   0  00    00   +28.3    6.0 ECU.   +0.0 ECU.     72
 5159 -12.5   72   0  00    00   +28.3    6.0 ECU.   +0.0 ECU.     69
 5042 -12.3   70   0  00    00   +28.3    6.0 ECU.   +0.0 ECU.     73
 4894 -12.3   72   0  00    00   +27.2    6.0 ECU.   +0.0 ECU.     71
 4775 -12.3   70   0  00    00   +26.1    6.0 ECU.   +0.0 ECU.     77
Old Aug 12, 2007 | 05:30 PM
mikesevo8's Avatar
Yes, if you fiddled with something, then you should definitely re-check your work for leaks.
Old Aug 12, 2007 | 05:52 PM
Warrtalon's Avatar
Mikesevo, that log isn't valid, because you start all your runs around 5000rpm and don't even peak until 5k. Is that even a stock turbo? Show a log starting at 3000rpm, because the stock turbo peaks closer to 3500rpm. Obviously, a turbo that peaks at 6k isn't going to taper much by 7k, but that's completely irrelevant in this thread.
Old Aug 12, 2007 | 07:05 PM
mikesevo8's Avatar
I guess validity is for Whoop_ass to decide ... the log was him ...
As they say over in OT ... you FAIL!!
Old Aug 12, 2007 | 07:08 PM
Warrtalon's Avatar
Whoop_ass was referring to the stock turbo, and you knew that. The whole conversation leading up to his comments was in reference to the stock turbo's behavior.
Only one person failed here, and it was not me.
Old Aug 12, 2007 | 07:10 PM
EvoVIIIJeremy's Avatar
Ok he is a simple answer. you just install new piping so it will not hurt to do a leak down and check then go from there. A retune will the new piping will help too.
Old Aug 12, 2007 | 07:12 PM
Warrtalon's Avatar
No need to do a leakdown test - just a boost leak test.
Blackevo mr
Cobb AccessPORT
Oct 28, 2015 12:51 PM
zsak
Nov 5, 2013 09:46 AM
PearceEVOix
Jan 20, 2012 07:39 AM
vortico
15
Jun 2, 2008 08:10 AM
roger smith
Aug 20, 2007 09:37 AM
