Oil Cooler Fan.... What Do You All Think?
Old Aug 25, 2007 | 10:57 AM
Robevo RS's Avatar
Originally Posted by reeferman
I would just install a larger oil cooler if you are have oil temp issues.
yes, and that can you lead to not get enough oil in the hard turns....
so damage the engine or blow it...
whatch out what you will get ! bigger oilcooler helps, if its a right design.
Old Aug 26, 2007 | 08:44 PM
98autogstspyder's Avatar
Originally Posted by moreryce
from the way i see it... a cooling fan will just slow the air down thats coming at it from the bumper... unless u are going to have it on all the time.. what is the speed of it going to be? wont it be more efficient of you are going 80 mph... without having a fan than to have a fan that only sucks air in at a speed of 50mph?
i would think just upgrading you oil cooler would be best...
No it will not slow the air down if you have a puller type fan.
A puller type fan pulls air into the oil cooler while the fan is mounted behind the oil cooler so it will not restrict any air flow.
I do not want a larger cooler because I think the stocker does a great job. However, when autocrossing you are in a low gear high rpm situation where not much air is going through the cooler. If you have a fan on in a sitaution like that or when you are stuck in traffic, I think it would benefit as well or even greater.
Thank you for the link to the B&M site. Looks interesting.
Boostin_hard
14
May 27, 2017 06:56 PM
lghtngyello03
10
Jul 22, 2016 03:26 PM
Balrok
Oct 23, 2015 05:36 AM
98autogstspyder
45
May 16, 2009 12:23 AM
bolsen
AEM EMS
13
Dec 12, 2005 08:44 AM
