boost leak?
Old Aug 27, 2007 | 02:22 PM
EvoJoeIX's Avatar
boost leak?
ok so i broke in my clutch and i turned up my boost to about 21 psi....
well when i get on it
the car hits 15 psi, kinda stays there for a sec, then it will take right off. the whole time it sounds like a big air leak when its over 15psi and it doesnt really feel like its going to fast...
im thinking maybe one of my lines going to the mbc have a leak, because it sounds like its comming from that area( air box, left side of car...) maybe i put a hole in it by accident when installing the clutch?
anyone ever experience this or have any ideas?
thanks
Old Aug 27, 2007 | 02:29 PM
TURBevO8's Avatar
do a boost leak check. you will need a cheap tester or you can make one, an air compressor, and some soapy water in a spray bottle. I bet you will find more than one leak too.
lncrevoviii's Avatar
Might be a leak.
But if it hits 15psi or so and stays there (meaning it doesn't go higher than 15psi) then it might be the soft spring in the MBC.
Old Aug 27, 2007 | 02:33 PM
EvoJoeIX's Avatar
before i put in my new clutch the mbc was holding 21 psi just fine though...so i dont think it would be the spring in it
Old Aug 27, 2007 | 03:04 PM
Definitely a leak.
Old Aug 27, 2007 | 07:27 PM
krazirob's Avatar
oh yeah physically check the IC pipes but or sure do a boost leak test. you will find your problem then i promise.....
Old Aug 27, 2007 | 08:22 PM
EvoJoeIX's Avatar
yea i have come to the conclusion theres definately a leak...
i drove my car tonight to figure out a little better what the problem might be and as soon as i hit 15psi, its just a loud air noise and the boost gradually drops
Old Aug 27, 2007 | 09:25 PM
evo150's Avatar
if you are still running the stock intake with snorkel make sure the 2 fastners are still there to hold the snorkle down.
Old Aug 27, 2007 | 09:27 PM
Warrtalon's Avatar
Intake Snorkel Syndrome perhaps? Call Bat-Talon.
Old Aug 28, 2007 | 02:16 PM
EvoJoeIX's Avatar
which two fasteners?
the ones that secure it to the airbox and turbo inlet?
edit:
what is intake snorkel syndrome?
Old Aug 28, 2007 | 08:33 PM
EvoJoeIX's Avatar
well tonight i went back and made sure everything i took off during the clutch install was tightend down....and it was
so i went out and drove my car a little bit to explore the problem some more....
if i get on it in 2nd gear it does the noise and my boost drops.once it starts doing the problem, it keeps doing it in every gear....also i notice my rpms increase, but my speed really doesnt go anywhere. is this just because lack of boost? or is it clutch related?
but if i go from a 3rd gear pull, i get full boost(23psi) and it holds it fine from 3rd on up.....its like once the problem starts, it keeps doing it, but if it doesnt do it, it runs normal....
im completely stumped on this one, and since it holds boost in a higher gear...im worried its not just a boost leak, and could be a clutch issue? just because i seen my rpms increase with no speed increase.... the clutch is brand new, has a little over 400 miles on it
Old Aug 28, 2007 | 09:04 PM
evo150's Avatar
edit:
the snorkel is the plastic inlet that is connected to the intake box that holds the filter. it directs cool air directly to your intake (pictured above circled in blue). youll see in the pic that the snorkel is held down by two plastic screws (circled in red). if these two screws are not there when you hit around 6000 rpm the snorkel will actually suck up against the hood youll hear a loud wistle/boost leak sound and your boost will drop.
not sure if this is your problem but doesnt hurt to look
Old Aug 29, 2007 | 01:42 AM
phat_bastage's Avatar
Boost leak test is the only way to tell.
If you had the transmission out, and the acd moved to the side, there is a good chance you could of broke off one of the plastic hose connectors on the Vacuum Regulator.
Its connected to a brass colored mount on the bottom back side where the acd/tcase hook together (that area)
That one cracked on me, it would hold to 15psi on the boost leak test.
Fuel Injector seals (lower) held until 19psi
Old Aug 29, 2007 | 04:35 AM
AlwaysinBoost's Avatar
what you described above sounds clutch related, RPM increases but speed doesn't is what a slipping clutch would do. Before you got pulling the trans do a simple boost leak test and see what you find.
Old Aug 29, 2007 | 09:02 AM
EvoJoeIX's Avatar
im pretty sure this is the problem since i took out the two screws so i could remove the snorkel easily, this way i could get to the bov and adjust it
ill put the screws back in and go test it out....
ill let you guys know whats up
