How Much Boost Off 2-Step
Old Sep 14, 2007 | 10:24 AM
  #31
bhamEVOguy's Avatar
Originally Posted by AZ EVO IX MR
25 psi @ 3600 rpm MoTec
Old Sep 14, 2007 | 10:38 AM
  #32
TouringBubble's Avatar
Originally Posted by dexmix
you guys need to learn the stock ECU!!!!
thanks TB
No problem.
Old Sep 14, 2007 | 10:59 AM
  #33
NIevo's Avatar
I build about 12-13psi at 6100rpm's. Raising the limiter will raise the boost to a certain extent. I was experiencing knock at the rev limiter and so I lowered timing which gave me another 2-3psi.
Old Sep 14, 2007 | 11:03 AM
  #34
Lancematic's Avatar
It is the tuning, not the car. Yes the higher the limiter is set will raise boost, but the ignition timing when it hits the limiter is what creates boost, and this delay is set by the tuner.
Old Sep 14, 2007 | 11:05 AM
  #35
konad's Avatar
my 2step is only at 4k rpm what gives
Old Sep 14, 2007 | 11:54 AM
  #36
4ringturncoat's Avatar
8psi @ 5500rpm
Old Sep 14, 2007 | 12:42 PM
  #37
AlwaysinBoost's Avatar
6k RPM stationary rev limit
4.35psi of boost out of the hole
Consistant low 1.7 - 60'
200+/- drag passes without a single driveline/clutch failure = Priceless.
Old Sep 14, 2007 | 12:51 PM
  #38
.MM's Avatar
.MM
14.5psi at 6000 rpms
house_of_senate
Sep 11, 2009 07:46 AM
sabastian458
Dec 11, 2008 12:31 PM
Snopro
Lancer How Tos / Installations
Sep 24, 2007 11:49 AM
bandwagon
15
Apr 11, 2007 10:12 AM
PURE EVIL 8
Jun 13, 2006 08:50 AM
