wtf is this noise?
Old Sep 16, 2007 | 04:17 AM
chaz517's Avatar
wtf is this noise?
Ok so for about a month now I have been getting this noise periodically while I'm driving, I tend to hear it more when I'm at stop and just slowly taking off, it sounds exactly like waht it would sound like if an exhjaust was bouncing and hitting the sway bar, but that's not the issue. I hear it occasionally when lettin of the ebrake, and ocassionally when I'm on a hill holding the brakes when I let them go. Any ideas? 42k miles thanks in advance
Old Sep 16, 2007 | 05:55 AM
AEvo2Nv's Avatar
by any chance did you check your brake lines or the brake pads itself?
Old Sep 16, 2007 | 05:59 AM
chaz517's Avatar
I chjanged my rear pads about 2 months ago, but I haven't check the front or inspected them at all, it def sounds like its coming from the front
Old Sep 16, 2007 | 06:18 AM
AEvo2Nv's Avatar
yeah try inspecting the front rotors and see if you have any life left in the pads at front.
Old Sep 16, 2007 | 08:00 AM
chaz517's Avatar
Ya? It doesn't sound likemetal on metal at all tho, but I can def check it out, cuz I'm stumped, any other inputs?
Old Sep 16, 2007 | 09:07 AM
Kubicide's Avatar
Sounds odd - but did you check the trunk-lid springs to see if they are hitting each other? Both my Evo's have made this type of sound, and it's an easy fix.
Look up under the rear deck in the trunk and see if they are vibrating together. There is a small rubber and plastic separator that has a tendancy to slip or move. Just try moving it to another location.
Last edited by Kubicide; Sep 16, 2007 at 09:09 AM. Reason: (Edit: assumed this was a metal-on-metal sound coming from the rear. If not ignore this post.)
Old Sep 16, 2007 | 09:09 AM
chaz517's Avatar
Please?
Old Sep 16, 2007 | 10:29 AM
AEvo2Nv's Avatar
he has a point chaz, if you checked what I told you and that isnt the problem do what he says if "that" isn't the problem.......get it checked out from a dealer if that isn't a problem as well.
Old Sep 16, 2007 | 10:49 AM
chaz517's Avatar
Allrite sounds good, I will def check botth out when I get hoem I've been on my fon this whole time, thanks 4 the help, sound comin from front tho, like under the drivier seate
Old Sep 17, 2007 | 12:47 PM
chaz517's Avatar
i hear it almost everytime i start the car as well. anthing to do with the downpipe bolts? maybe 1 is loose? engine damper? i dunnno
Old Sep 19, 2007 | 09:35 AM
chaz517's Avatar
hmmm now i am starting to think maybe its the tranny or clutch. there is no slipping of the clutch and the tranny still shifts fairly smooth, but i was trying to figure out the problem just now and so i was in my garage going in reverse and then rolling up in 1st, each time right after the clutch grabs and the car starts 2 move forward it makes that clunk noise like someone knocked on wood. someone has to have some idea of what this could be. last resort is dealer. thank you
Old Sep 19, 2007 | 09:45 AM
tweakdsm's Avatar
did you inspect your downpipe ? if its not hitting anything? could be hitting your oil pan on the top, make sure you check dp for clearence.
Old Sep 19, 2007 | 09:49 AM
chaz517's Avatar
ya thats what i was just checking, i put it on ramps and brought a flashlight, but it doesnt hit anything, i just hope nothing is starting to go in my tranny
Old Sep 19, 2007 | 09:55 AM
tweakdsm's Avatar
did you check the clearance between the dp and oil pan? you can check it with a piece of paper if it goes around it.
now how many miles on your evo? what oil did you use for T/C and rear diff?
Old Sep 19, 2007 | 10:38 AM
chaz517's Avatar
40k and oem fluids, and no it doesnt hit the oil pan it just barely clears it
