front engine mount (lower)
Old Sep 26, 2007 | 09:46 PM
filter's Avatar
ok i done some searching but have a few questions that dont seem to be covere.
1. do any of these bolts need to be torqued to a certain spec or just as tight as you can get them.
2nd how much does the engine move? will i be able to move to push it back up? or will the bolts move it back up in place?
Old Sep 27, 2007 | 06:32 AM
filter's Avatar
anyone?
Old Sep 27, 2007 | 07:33 AM
evolved83's Avatar
i do believe that the bolts need to be torqued to a certain spec
Old Sep 27, 2007 | 07:37 AM
4WS Tuning's Avatar
theres a few write ups in the how section... one of them has the specs.
Just a reccomendation from recently doing doing one on my car.. agency power
Before you bolt down the mount for the motor mount. attach the motor mount to the motormount bracket first as its a pain in the *** to get lined up if u do that last.
Cheers!
Old Sep 27, 2007 | 07:43 AM
evolved83's Avatar
Cheers!
i know the agency power mount comes with bolts, but can you use the stock ones?
Old Sep 27, 2007 | 11:19 AM
evo150's Avatar
the 14mm bolt that goes through the motor mount is torqued with 49 ft lbs. the two bolts that hold the motormount to the frame should be torqued to 35-39 ft lbs. check out step number 17 of this how to thread https://www.evolutionm.net/forums/sh...d.php?t=191103
Old Sep 27, 2007 | 11:24 AM
4WS Tuning's Avatar
why reuse them?
Use as needed.....
Just remember to put the bolt that goes thru the motormount first before bolting up the bracket.
Cheers!
Old Sep 27, 2007 | 11:33 AM
Evoryder's Avatar
why reuse them?
Use as needed.....
Cheers!
eh?
Old Sep 27, 2007 | 12:55 PM
evolved83's Avatar
why reuse them?
Use as needed.....
Cheers!
i bought a motormount from a member on here but didn't get the supplied bolts, and i am not sure if they are a different size.
Old Sep 27, 2007 | 04:06 PM
filter's Avatar
i looked through that write up a few times and never seen that till now.
Old Sep 28, 2007 | 02:40 PM
4WS Tuning's Avatar
oh well in that case u can reuse them... thats not a prob
i jsut like new shiny things =-)
Old Sep 28, 2007 | 02:47 PM
ItalyIX's Avatar
Just reuse the same ones and torque to specs.
Real easy install.
Morgan Carter
Outlander Sport
Oct 15, 2015 04:35 PM
Incognito
Sep 23, 2010 06:00 PM
maverick31210
Lancer Engine Tech
Jun 25, 2010 07:57 AM
Cyloc
Northeast Region
Sep 18, 2008 04:18 PM
Lil red '03
Lancer Tranny/Drivetrain Tech
29
Sep 10, 2006 09:25 AM
