No lift to shift mod on stock ECU VIDEO!!!
Old Sep 29, 2007 | 05:37 PM
  #46
dxbevo9's Avatar
me?? i dont need no redbull...my eyes are wide shut
Old Sep 29, 2007 | 05:43 PM
  #47
funevo's Avatar
still cant be to easy on the drivetrain. but i have done it before and it is quicker
Old Sep 29, 2007 | 05:47 PM
  #48
gsrboi80's Avatar
Its really cant be no harder on the drivetrain than a lifting run down the 1320 IMO
  #49
evo8426's Avatar
i dont see how it can be easier on it
Old Sep 29, 2007 | 07:03 PM
  #50
4TUN8's Avatar
because the rev's go down not up when you flatfoot.
Old Sep 29, 2007 | 07:58 PM
  #51
srt2evo's Avatar
From what I understand, the TPS Position is controlled by the ECU. You can program the ECU to let off the throttle when the clutch is stepped on. I'd imangine this would actually be less of a stress on the drivetrain in a 1/4 mile drag.
Old Sep 29, 2007 | 08:27 PM
  #52
4TUN8's Avatar
You wouldn't want that because it would shut the throttle plate.
Old Sep 29, 2007 | 08:38 PM
  #53
90GSX-03EVO's Avatar
Actually, our cars aren't drive-by-wire, so it wouldn't shut the throttle plate. There is a physical cable that connects the throttle plate and the gas pedal. You could possible shut off spark or injectors, but not physically shut the throttle plate by ECU manipulation.
Old Sep 29, 2007 | 09:03 PM
  #54
4TUN8's Avatar
I'm retarded you're absolutely correct.
Old Sep 30, 2007 | 12:04 AM
  #55
EvoJoeIX's Avatar
what i dont understand is how all these people think its the same thing as power shifting....
its easier on the drivetrain because it cuts the revs to where they would normally be if you lifted to shift, except you now have full boost between shifts. when you powershift at 7500rpm or whatever, the car will drop rpms and then bulid back up when you let out the clutch. that intial shock when letting out the clutch will kill your transmission and clutch and rear diff.
i think everyone is confused because in the vid, he doesnt have the rpms set to drop a lot, so its just looks like hes powershifting.
Old Sep 30, 2007 | 12:26 AM
  #56
DeeezNuuuts83's Avatar
^ Well, the confusion was just the lack of a basic explanation of what was going on since all we could really get from the video was the gauge readings and engine sounds, while the first couple pages were full of posts just saying "I should get this."
Old Sep 30, 2007 | 01:11 AM
  #57
nightwalker's Avatar
hmmm... when I shift, I don't hear my bov, or do I see the boost drop.
Old Sep 30, 2007 | 09:08 AM
  #58
EvoJoeIX's Avatar
i know its a confusing video....
it would be a lot better if someone would make one that shows the rpms dropping a little more...
i think people will then understand the concept a little more
  #59
EvoJoeIX's Avatar
well how do you shift?
the point of nls is not to just hold boost inbetween gears....
Old Sep 30, 2007 | 12:54 PM
  #60
dsmfan95's Avatar
Originally Posted by ShamelessCookie
To everyone who doesn't understand this mod...
The patch is equivalent to DSMLink's Clutch Cut... it is fuel cut as soon as you touch the clutch, as long as you are above the TPS and speed threshold.
What does this mean?
It means the throttlebody stays open and the intake mani doesn't drop into vacuum.
You are still revving the engine down, as fuel is cut... how much you rev the engine down is configurable in the ECU (as well as TPS and speed thresholds).
So the shock to the drivetrain is stock-like, in that the RPM is still coming down same as stock, the clutch engagement is still like stock... the difference is the amount of time it takes you to hit peak boost after a shift... that's it !!!
Also, the OP has the RPM drop set to 100rpm, so when he hits fuel cut, it only drops 100rpm (which takes basically no time at all) and then re-introduces fuel... so he has a very aggressive RPM drop setting which WILL introduce more shock to the drivetrain than stock. The default drop for this patch is 1500RPM. I will probably use 750RPM or 1000RPM.
Thank you. That is what I was looking for.
