Fuel Pump?
Old Oct 11, 2007 | 05:51 PM
Derek2841's Avatar
Fuel Pump?
I have talked to some members and received the advice that I need a fuel pump with my new mods (cams, full exhaust,uicp,licp,tune) I talked to my parts supplier and install shop and they said it is not necessary until I am making more power, such as a turbo upgrade. I know you guys know everything about evos, so I would like to know the benefits of a aftermarket fuel pump? Is it overkill? Does it help with power? Thanks in advance.
I drive a IX MR.
Old Oct 11, 2007 | 05:53 PM
upstatescevo's Avatar
its a cheap saftey investment i would do it regardless
Shacochis06's Avatar
iono what ur supplier is talking about but you DEF need a fuel pump...especially wit a tune...Do u already have a tune or planning a tune?...but no matter wat u def need that fuel pump wen ur makeing more power
Old Oct 11, 2007 | 05:55 PM
DSM GSR04's Avatar
When you get tuned, the stock fuel pump will be maxed out and will be stressed to the point of premature failure, so a whinebro would be a great investment.
Old Oct 11, 2007 | 05:58 PM
Evoryder's Avatar
Simple test.
Do a simple data log. 3000rpm-7000rpm. RPMxIPW/1200
post results...
Anything above 95% then you'll need a fuel pump...you'll need one anyways eventually. I've heard the IX stock fuel pump is a little better than those on the VIII's
Old Oct 11, 2007 | 06:09 PM
yah ive heard that the 9 pump is better but i would try it over a 80 dollar part
Old Oct 11, 2007 | 07:04 PM
EiVxO's Avatar
+1 with replacing with a walbro or something to that calibur.
Old Oct 11, 2007 | 07:08 PM
Dont Try To Run's Avatar
get a walbro for sure
