Question on changing trans fluid.
Old Oct 20, 2007 | 01:08 PM
cs82685's Avatar
Ok well I'm getting ready to change the fluids in the Evo and have been using this link as a reference...
Evo Driveline Fluid Change
Noting this particular part...
2.9 quarts of Gear oil API classification GL-4 SAE 75W-85W or 75W-90 (I used Redline MT-90)
0.58 quarts of Hypoid gear oil API classification GL-5 SAE90 (I used Redline 75W90)
0.58 quarts of Hypoid gear oil Mitsubishi Genuine Gear Oil Part No. 8149630EX or equivalent (I used Redline 75W90)
I was planning on following this for doing this, however, shopping around for the gear oil, I cam across this item on extremepsi's website...
Redline PowerPack : Mitsubishi Lancer EVO VIII/IX #20406
Mitsubishi EVO PowerPack
The Mitsubishi Lancer Evolution PowerPack helps the complex all-wheel-drive system to transfer more power to the wheels across the power range and with less vibration.
Works with Lancer EVO VIII, EVO MR, EVO IX, and EVO RS and includes 6 quarts of 10W30 engine oil, 2 quarts of MTL and 1 quart of MT-90 (to be combined for use in the transaxle, mixing to meet the Evo's 75W85 gear oil spec), 1 quart of 75W90 for the center differential and 1 quart for the rear differential, 1 bottle of WaterWetter for the radiator, 1 bottle of SI-1 Complete Fuel System Cleaner, a sticker kit, and a Red Line Oil embroidered hat.
The bolded portion is what's got me. Should I just use 3 quarts of MT-90 like in the write-up, or should I go with the mix (2 quarts MTL and 1 quart MT-90) as recommended through the 'redline power pack' on extreme's website.
TIA and sorry if this has been discussed, I won't lie aside from finding and reading through the write-up I didn't really search, but will in the meantime while seeing if someone else has an answer. (I like to do it that way, post and then search while waiting for replies )
Old Oct 20, 2007 | 01:19 PM
RenEvoIX's Avatar
(2 quarts of MTL and 1 quart of MT-90 (to be combined for use in the transaxle, mixing to meet the Evo's 75W85 gear oil spec), i ve not head of this.. hope some of u guys can give some details on this..
Old Oct 20, 2007 | 01:26 PM
chaotichoax's Avatar
there are quite a few who mix mtl and mt-90...that's how you get the 75w85 rating that's required
some just use straight mt-90
it's a preference to feel and protection
Old Oct 20, 2007 | 01:28 PM
EVOLVEU's Avatar
2 mtl 1 mt-90 worked great for the longest. That is what Shep recommended.
Old Oct 20, 2007 | 03:55 PM
cs82685's Avatar
Interesting, but it's good that you can do it either way. Thanks for the help guys
~EVILEVO~
21
May 4, 2023 04:17 PM
eddy5201314
12
Dec 24, 2016 04:33 AM
Clipse3GT
15
Jun 19, 2012 06:54 AM
4-BNGR
35
Jul 10, 2005 04:22 AM
runny_yolk
Apr 12, 2004 08:09 PM
