amsoil users look here
Old Oct 22, 2007 | 08:58 AM
schred86's Avatar
id like to start a thread about ur guys experiences with amsoil lubes
id like to know how many of you guys use amsoil throughout your whole evo.
im currently running it for the engine/oil filter, but im thinking about putting it in the trans rear diff and transfercase. how many of u are doing this and do u recommend it. also since this engine oil is rated for 25k miles, how long do u guys wait to change it?thanks again
Old Oct 22, 2007 | 09:00 AM
justboosted02's Avatar
stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC stock fluid in TC............................................
Old Oct 22, 2007 | 09:03 AM
deadbeatrec's Avatar
i currently use amsoil in the engine but am going to replace all my TC and gear fluids with stock Diaqueen.
Old Oct 22, 2007 | 09:06 AM
schred86's Avatar
i am probably going to as well but id like to see who has used amsoil everywhere, and their thoughts on it
Old Oct 22, 2007 | 12:34 PM
schred86's Avatar
nobody else huh?
Old Oct 22, 2007 | 12:36 PM
Talon's Avatar
I've used it in my DSM as engine lube during track days. No issues. I don't anymore because it's a pain to get...
Old Oct 22, 2007 | 01:01 PM
TouringBubble's Avatar
I plan to run it in the drivetrain as well, but I haven't gotten around to changing all of that yet. I've got a preferred account with Amsoil.
Old Oct 22, 2007 | 02:49 PM
mplspilot's Avatar
I got amsoil everywhere even in rear diff. Interval depends on the type you're getting.
Old Oct 22, 2007 | 04:21 PM
evo150's Avatar
i run stock fluids in the tranfer case and rear diff. but i do run amsoil in my tranny.
Old Oct 23, 2007 | 05:49 AM
schred86's Avatar
how does the tranny feel, im a preferred customer too, so i get nice prices and was looking at the oil u pictured above for the trans
Old Oct 23, 2007 | 06:03 AM
schred86's Avatar
mplspilot , what do u put in the t/c and rear diff?
Old Oct 23, 2007 | 09:19 AM
EVOIIIM3's Avatar
I've run stock, Redline, & Amsoil.
Redline seams to "feel" the best, but has tough 1st shifting till it's warm
Amsoil, is the smoothest feeling, no 1st gear issues, picked up a couple of MPG
Stock, lowest MPG, the car feels sluggish after having Redline in it.
I've also noticed that the stock fluid heats the engine oil up faster, this tells me there is more friction, it also seams to have a slightly higher under hood temp when you stop.
FWIW< I was using the Amsoil 2000 series stuff, that they don't make anymore.
Old Oct 23, 2007 | 09:27 AM
schred86's Avatar
thanks for the input
Old Oct 23, 2007 | 09:48 AM
mplspilot's Avatar
I got 75w-90 severe gear fully synthetic (GL-5) in tcase and rear diff.
I suggest getting a slip-differential additive for the rear. I run without it with no problems though (no sounds or chatter)
Old Oct 23, 2007 | 09:58 AM
EVOIIIM3's Avatar
Most high end lube will have the additive in there, most of them will tell you if you need to add it.
