MBC / Max boost?
Old Oct 23, 2007 | 11:04 PM
LoveBoost's Avatar
MBC / Max boost?
I am thinking of getting a manual boost controller. Just wondering which brand is good.. I've heard of many using Hallman. Is it better to go with the ball/spring type?
What is the disadvantage with going with the cheaper <$50.00 ebay ones?
If I am running with stock injectors, stock internals, HKS RS, Tanabe DP, Espelir exhaust, Cosworth cams, Walpro fuel pump, ECU flash/dyno tune, currently running 22psi with flash.
What is the highest I can run (while being safe)? 26psi? 30psi?
Thanks for the info in advance.
Old Oct 24, 2007 | 03:58 AM
recompile's Avatar
You should get re-tuned if you're turning up the boost. On 93 octane, your upper limit is probably 26psi (on really GOOD 93 like Shell), but most don't run that high... most would say 23 or 24 tops.
On meth injection or C16, probably 28psi.
But keep in mind on the stock IX turbo, you will taper to 20psi @ redline no matter how high you set the MBC to spike... so depending on your goals for the car, you may be looking at a new turbo
Old Oct 24, 2007 | 09:45 AM
SRT8yOu's Avatar
off topic but i see you mentioned shell gas. What are other good gas companies and what are the bad ones??
Old Oct 24, 2007 | 09:54 AM
lemmonhead's Avatar
the hallman is a ball spring type. uses a ceramic ball.
Old Oct 24, 2007 | 11:04 AM
Insanenoodle's Avatar
I have a TurboSmart mbc i bought for 25 bucks. Hold's the boost to redline just fine. I'd say 23psi max on 93.
4b11slayer
Nov 10, 2016 07:57 PM
Blk04evo
Mar 22, 2007 01:11 PM
ReNoEvO775
10
Oct 9, 2006 08:51 PM
TKMotorsports
31
Sep 19, 2006 11:47 PM
wheredafucrwe
Oct 26, 2004 12:10 AM
