Weird issue- possibly plugs
Old Oct 26, 2007 | 03:50 PM
frenchy99's Avatar
Today driving back from work, I was on the freeway.I WOT in fifth gear(trying to pass a car)and my car started shaking and sputtered. I was able to reproduce it a second time, but then it stopped! I am thinking it might be my plugs? Do you guys have any suggestions?
Old Oct 26, 2007 | 04:01 PM
[EVO]Cookie's Avatar
it's really easy to find out pull the plugs and look at them.
Old Oct 26, 2007 | 04:06 PM
bmguser's Avatar
no codes were thrown?
Old Oct 26, 2007 | 04:18 PM
-PMP-twitch's Avatar
bad gas???
Old Oct 26, 2007 | 04:22 PM
frenchy99's Avatar
No codes! I tried to reproduce a third time and it wouldn't do it!
frenchy99's Avatar
Originally Posted by -PMP-twitch
bad gas???
Possibly? But usually when it bad gas my car idles like crap
Old Oct 26, 2007 | 04:23 PM
frenchy99's Avatar
Maybe I am running my plugs are too cold(br8es) for my mods
Old Oct 26, 2007 | 04:26 PM
Wazvette's Avatar
It sounds like your surging.
Old Oct 26, 2007 | 04:30 PM
frenchy99's Avatar
What would cause that? My mods are Buschur TBE MAGNAFLOW, Walbro 255, nisei LICP, intake,MBC
Old Oct 26, 2007 | 04:31 PM
precisi0n's Avatar
br8es are too cold for those mods
Old Oct 26, 2007 | 04:32 PM
tcollins's Avatar
I was compromise once because of a plug that went bad and no NGK's were available so I ended up with Champion that were spec'd for the vehicle. I had the same problem you're experiencing because the flame from the Champion's kept blowing out under higher boost. Switching back to the NGK's solved the problem. Bosch seems to be ok as well. I learned that just because it is spec'd for the LanEVO doesn't mean you're going to get that performance. Also check plug gapping. Through my plug experience, even the dealership can gap the plugs wrong. Bad gap can give the same symptoms. Man, that was a bad week.
Old Oct 26, 2007 | 04:39 PM
frenchy99's Avatar
I Ran those plugs all summer no problem, till now!
Old Oct 26, 2007 | 04:41 PM
frenchy99's Avatar
I have brand new BPR7ES, I am going to put those on. Thanks for the input By the way did your boost drop when that happened?
Old Oct 26, 2007 | 04:55 PM
tcollins's Avatar
I was more concerned about all the shuttering than to look at the boost gauge. I don't think I hit max because it was shuttering before then. My boost dropped after the dealership installed the new NGK plugs and performed an injection cleaning service and didn't install the I/C to manifold piping properly so I blew it clean off when I was 1hr away from anything, in the pitch black of night, on a lone highway, at -20C in the winter. Crap that week sucked.
Old Oct 26, 2007 | 05:37 PM
tcollins's Avatar
Um, those are the $2 plugs verses the $20 IGR7A-G's? Even the defunked Iridium plated Champions I had were like $8->$12 each. You're driving a race car. Its going to cost like a race car.
