OEM Style Boost Gauge?
Old Nov 1, 2007 | 02:16 AM
bboy_RES's Avatar
i'm looking for a PSI boost gauge that will match the oem evo 9 mr gauges. i want something like the defi d gauges, but i dont want to get a control unit. i just want to be able to splice the gauge into my existing wiring harness. also, are the oem gauges 52mm? i'm only gonna be boosting 21-22 psi and the stock mr boost gauge goes up to about 21.5 psi. i was thinking i could get away with using the stock gauge, but i realized that i wouldn't be able to tell if i was over boosting.
Old Nov 1, 2007 | 05:16 AM
TouringBubble's Avatar
The VDO Vision series looks very similar, but they are back lit. Great gauges as well. Quite accurate and affordable.
Old Nov 1, 2007 | 05:19 AM
LoCo4's Avatar
You want the Omori boost gauge then....helped with install on my buddies (I-Dom-In-8).
Old Nov 1, 2007 | 05:20 AM
LoCo4's Avatar
Here is a pic on his car:
Old Nov 1, 2007 | 10:54 AM
bboy_RES's Avatar
^^^ that gauge looks great! is that a 60mm because it looks slightly larger than the stock gauges. do they make them in 52mm? does the back light match the stock gauges as well? i guess i could just try to solder led's on it if it's possible.
Old Nov 1, 2007 | 11:45 AM
bboy_RES's Avatar
where can i buy it? i tried searching on yahoo, but it just gives me a lot of installation guys and stuff.
Old Nov 1, 2007 | 11:48 AM
RoBear's Avatar
+1 on the Omori
Old Nov 1, 2007 | 11:52 AM
Chemwarrior's Avatar
The Stewart Warner gauges from 42nd Draft Designs are also a great option.
Old Nov 1, 2007 | 01:19 PM
LoCo4's Avatar
I want to say it was bought through Subydude.
Old Nov 1, 2007 | 06:50 PM
I-Dom-In-8's Avatar
Thanks hector for letting me know about this..
Its the 45mm gauge and i got it from Jspec
Heres another pic..
Old Nov 1, 2007 | 06:54 PM
LoCo4's Avatar
IIRC didn't you originally order through Subydude?
Heres another pic..
Old Nov 1, 2007 | 06:59 PM
I-Dom-In-8's Avatar
LOL..yeah i did but it was on backorder and i didnt want to wait
Old Nov 1, 2007 | 07:02 PM
I-Dom-In-8's Avatar
Couple of things...you will have to use a dremel to make the stock hole a little bigger, Not a whole lot so dont worry.. the link i put up is for full color, you can go from green,red,blue,white and so on..hope this helps..
Old Nov 1, 2007 | 07:14 PM
LoCo4's Avatar
He PMed asking that info..... I got you covered Kevin!
Old Nov 1, 2007 | 08:11 PM
bboy_RES's Avatar
haha thanks a lot guys! this helps alot. i assume this gauge will just splice into the existing wiring harness?
