alignment after clutch replacement
Old Nov 2, 2007 | 06:38 AM
XIEvolutionIX's Avatar
I just had my oem clutch replaced by the dealership and noticed while driving home that the alignment appeared to be slightly off. in order to drive perfectly straight i had to hold the wheel slightly to the left and i know you have to take off most of the front left wheel assembly in order to get to the transmission to replace the clutch. im thinking something might have been thrown out of whack there. has anyone heard of this happening or has it happened to them?
Old Nov 2, 2007 | 06:40 AM
btw i put this in general cause it deals with drivetrain and suspension and figured people who know about both would see it.
Old Nov 2, 2007 | 06:44 AM
evo 8 ya's Avatar
You don't have to mess with anything alignment related when replacing a clutch.
Old Nov 2, 2007 | 06:51 AM
AlphaMale's Avatar
From: Michigan, Indiana, depends on the time of day.
while removing the front axle they likely removed the tie rod end and rather than removing it from the knuckle (which can be a paint) they might have chosen to seperate it at the inner/outer tie rod connection. This would allow them to 'accidently' mis-align your car while putting it back together. I would return to the dealer and suggest that while putting the vehicle back together they neglected to verify their work upon completion and request the vehicle be aligned back to the specifications it was at prior to you bringing it in for cluth replacement.
If they're dicks about it, get ****ty and ask for contact information for the regional manager.
Old Nov 2, 2007 | 06:53 AM
DSMEVOLUTION's Avatar
Yeah but it still happens because you have unbolt and the lower suspension components. If you get an alignment you'll be fine. I remember when I had my old 95 tsi I brought it to AMS to ahve them change the passenger side axle seal. When I drove it home my alignment was all out of whack. Sure you don't touch any adjusting components but when you bolt the lower suspension back together it might be slightly off from where it was before.
Old Nov 2, 2007 | 06:54 AM
BTW...how much did that install cost you?
Old Nov 2, 2007 | 07:05 AM
It was the regional managers car before i bought it... hes the main reason i had to get the clutch replaced. Old retard didnt know how to drive..
$1575 even. Waaay to much, but i wanted to keep my warranty cause i still have the slightest sliver of hope for Mitsubishi.
Old Nov 2, 2007 | 07:17 AM
AlphaMale's Avatar
Then go above him....
-Josh
Old Nov 2, 2007 | 07:33 AM
Mr. Evo IX's Avatar
Also they may have dropped the entire steering rack as you can do the clutch install that way also.
Old Nov 2, 2007 | 07:39 AM
ohEVO18's Avatar
definately take it back up to them and let them know you've had a s****y time since they did the work...it always help if you make them believe you have the BBB number in your phone...
joonvang
Feb 24, 2017 08:08 PM
KGHtheII
11
May 29, 2012 07:37 AM
gmed
21
Jan 15, 2009 09:31 AM
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
dek0026
May 15, 2008 03:31 AM
