accuracy of greddy profec b?
Old Nov 6, 2007 | 03:25 PM
max2evoix's Avatar
how accurate is the greddy profec b spec 2 boost controller reading? compared to a boost guage? is it higher,lower etc... just wanna know so i can adj it accordingly..and no i dont have a boost guage installed..any info would be greatly appreciated...
Old Nov 6, 2007 | 03:28 PM
bigric09's Avatar
ive heard it is one of the most accurate boost readings available. My defi gauge reads 1 pound heavy at boost then the controller and then usually .5 a point lower in vacuum. Last few times on the dyno, the dyno reads the exact boost my greddy does although they are pulling boost from 2 different points. My defi and greddy share the same boost source but read different
Old Nov 6, 2007 | 03:29 PM
4TUN8's Avatar
Probably because your defi is mechanical (maybe?) and the profec I assume runs of a MAP type sensor which would be more accurate.
Old Nov 6, 2007 | 03:30 PM
bigric09's Avatar
my defis are the BF series... the EBC does not use a map sensor, it simply reads the vacuum source supplied by running a hose from the unit directly to a T in the vacuum system.... they are both pulling reference off of the same T
Old Nov 6, 2007 | 03:31 PM
max2evoix's Avatar
so pretty much the same? i have a prosport guage that im installing in like 2 weeks..
Old Nov 6, 2007 | 03:32 PM
bigric09's Avatar
pretty close but id say more accurate than my gauge
max2evoix's Avatar
ok thanks man..
Old Nov 6, 2007 | 03:33 PM
4TUN8's Avatar
The sensor is more then likely internal to the unit, much like the control unit for the SMC alky injection.
Old Nov 6, 2007 | 03:35 PM
bigric09's Avatar
you are probably correct
Old Nov 6, 2007 | 03:44 PM
kreionic's Avatar
From my use of it. Its basically dead on with a dyno, my boost gauge, and my jdm map sensor. The profec is off like .1 from a zeroed JDM map on my car. It could vary car to car I suppose
Old Nov 6, 2007 | 03:48 PM
max2evoix's Avatar
thank you ^^
RobertIsl
Apr 27, 2017 10:29 AM
Shy
Apr 10, 2010 07:57 PM
suprafabs
Feb 12, 2010 01:43 PM
hamx0r
May 2, 2007 08:01 PM
brandonbigdog
11
May 3, 2005 06:54 AM
