What could this problem be
Old Nov 6, 2007 | 03:56 PM
richevo26's Avatar
hey guys, i have got an evo 9 and lately its been acting wierd, the car at idle idles at about 500 rpm and whe i let offf in 1st, 2nd, 3rd etcc..the car doesnt engine break it, it goes faster..this sounds like a boost leak but ihave honestly checked every possible line and theres no holes in the line aor anything,, that else should i check and what could this be...thanks for ur help guys
Old Nov 6, 2007 | 04:00 PM
05evoGSR's Avatar
i would check things like the idle adjustment screw, throttle cable and things around the throttle body...sounds like something may have come loose.
Old Nov 6, 2007 | 05:09 PM
k2boarder3187's Avatar
+1 check the throttle cable to see if its in its little clip on the valve cover
Old Nov 6, 2007 | 06:54 PM
richevo26's Avatar
i took out the intake box and the upper intercooler pipiing tonght to see for any leaks on any of the lines or pipes...after putting it back together i had a check engine light....omg help me guys....im gonna flip out
Old Nov 6, 2007 | 06:57 PM
56Hotrod's Avatar
Did you hook up your mass air sensor after putting the intake box back in?
I agree with the throttle cable, make sure it isn't binding.
Old Nov 6, 2007 | 07:06 PM
barneyb's Avatar
Check for the throttle sticking and for deposits on the throttle plate or in the throttle body bore at the throttle plate. Remove any deposits with solvent on a cleaning cloth.
Old Nov 6, 2007 | 11:19 PM
richevo26's Avatar
i can just take off the upper intercooler pipe(the rubber hose) and dio that right?
Old Nov 7, 2007 | 12:16 AM
barneyb's Avatar
Yup
Old Nov 7, 2007 | 12:00 PM
richevo26's Avatar
Yup
ight for some reason the idle is back to normal but still the car doesnt engine break really at all and just feels wierd when i go into every gear....could my clutch just be goin?
Old Nov 7, 2007 | 02:09 PM
richevo26's Avatar
anyone?
