Sun roof won't slide back
Old Nov 13, 2007 | 11:57 AM
vroomevo's Avatar
as title says, it will not slide back!! well, it initiates, it moves little bit and won't move.
checked it from the outside and it appears that rubber seal around sunroof won't roll under the ceiling.
does anyone have similar problems??
it's 2003 and parked outside during work.
will appreciate any input.
Old Nov 13, 2007 | 12:00 PM
DC2TMike's Avatar
had the same problem a couple of times. try tilting the roof first a couple of times and then open up the roof. have an 03 as well.
Old Nov 13, 2007 | 12:03 PM
EclipseMblue's Avatar
i believe there is a tech/how to on fixing that problem
Old Nov 13, 2007 | 12:05 PM
sekula's Avatar
Same thing happened to my 03...the sunroof wouldn't slide back and you could just hear the motor spinning and spinning and it got stuck a couple times too, but after 20 mins of grappling with it, i pulled it forward and will never touch it again!
Old Nov 13, 2007 | 12:09 PM
strange my 03 sunroof is working fine all though i barley ever tilt it or open it
EvoHung's Avatar
This subject has been covered before. Try lubricating the rubber piece.
Old Nov 13, 2007 | 12:13 PM
JDMCT9MR's Avatar
That sux.Even though this type of problem exists with sunroofs I do miss having one.
Old Nov 13, 2007 | 12:45 PM
mathgeek's Avatar
I had the EXACT same problem within the last week. If you remove the headliner (see the write up in this forum) you'll most likely find that the motor is about to fall off. There are three screws that mount the moonroof motor to the roof of the car. Mine was barely hanging on by one loose screw. The other two had completely fallen off. The griding sound you hear is the motor unable to grip the gears (because it's loose and not able to align correctly) that slide the moonroof back and forth. A number of people have had this problem. If you're willing to go throught the hassle of taking off the entire headliner and reseting the motor, that should fix the problem forever. The dealer (or any shop) will charge you at least 3 hours labor. It took me about that long. It was worth it. If you decide to try it, you can PM me if you need any more info and I'll be happy to help.
Old Nov 13, 2007 | 01:44 PM
vroomevo's Avatar
i don't think it's motor. i don't hear motor spinning. i just seem to stuck under the roof. looks like it's needs lubrication.
any recs on lubricatoin??
thanks.
Old Nov 13, 2007 | 02:17 PM
W0459732's Avatar
wd 40
Old Nov 13, 2007 | 02:29 PM
nick735's Avatar
+1
Old Nov 13, 2007 | 06:25 PM
mathgeek's Avatar
thanks.
After my motor stopped grinding the first time, it stayed quiet after that. The control did absolutely nothing when I tried to open/close the moonroof - it was just stuck. I have a feeling that your motor is loose from its mounting and jammed (which is why you don't hear anything). A sufficient number of owners have discovered that their motor wasn't tightened correctly from the factory. You can try lubricating the rails and such but if that doesn't prove effective I'd recommend that you remove the headliner and take a look. Here is the link to the DIY write-up.
https://www.evolutionm.net/forums/sh...=sunroof+stuck
Again, it's not tooooo tough a job. It just takes a little time and patience. BTW, I originally posted in this thread in response to the individual who experienced the grinding motor. I'm positive that HIS problem is the same one that I had. Your problem may be different, though, and hence my suggested remedy may not work.
Old Nov 13, 2007 | 08:07 PM
steevo's Avatar
I had the same problem in my '03. Seemed to occur more often in cold weather. I've had problems with every sunroof I've owned. Don't think I will get one again.
KiranM
Oct 16, 2016 03:28 PM
KiranM
Oct 16, 2016 03:26 PM
05EV08
Jun 20, 2016 11:46 AM
jeg5263
Lancer Tranny/Drivetrain Tech
Mar 6, 2016 07:50 PM
kelvinTME
May 14, 2012 05:43 AM
