Update
Old Jul 18, 2003 | 08:25 AM
Shawn Glass's Avatar
Update
Well everything was going fine on the restoration of my car until I got to the IC/BOC plumbing. Apparently RMR either cut down the factory part or used their own for the bov return line from the IC pipe. So when I put the stock part on it was like 3" short . So I found 1 place in the US that has that part (San Antonio, TX) and got it shipped overnight so I can get the car running tomorrow.
One odd thing I noticed, but didn't think twice at the time I noticed it. When draining the oil, I noticed the drain plug had a dab of grey rtv . Didn't think twice about it. So I got the drain plug back in, new filter on, etc. etc. Fill the oil, cross my fingers, yay no leaks at the oil drain line from the turbo to the pan. But I notice oil is seeping at the drain plug, wtf? I didn't have a drain plug gasket so could that be it, or do you think those idiots may have stripped the threads? It screwed back in easy, I know I didn't overtighten it as I torqued it to specs. Well in any event, I have a new drain plug coming as well as a new gasket. I'll drain the oil again and install the new parts and see if that fixes the seeping. If not, just another item to ad to my evergrowing list of issues that will be in my lawsuit against RMR.
Shawn Glass
p.s. Mike @ Metro Mitsubishi in San Antonio told me they have a CRAP LOAD of factory accessories for the EVO. He said he will sell at dealer cost to get rid of them, if anyone is interested you can call the dealership at (210) 340-8222, ask for Mike in parts. Tell him you were referred by me so he will give you the discount.
Old Jul 18, 2003 | 08:27 AM
blonde's Avatar
good luck Shawn with everything.
let us know if you need anything.
Old Jul 18, 2003 | 09:11 AM
Diesel's Avatar
does that dealer have a website...?
Old Jul 18, 2003 | 09:15 AM
http://www.metromitsu.com
Shawn
Old Jul 18, 2003 | 09:29 AM
Coolguy949's Avatar
What about the washer on the drain plug? Do you have one?
Old Jul 18, 2003 | 09:32 AM
!!!!!!!!!!!!!0Z's Avatar
In Timeout
Shaun, the Evo gonna be ready to run in CAL SLAM STAGE IIIon Aug 2?
Old Jul 18, 2003 | 09:35 AM
Secret Chimp's Avatar
Shawn, You sure it was rtv? The inside of the oil pans look as if they were painted with the drain plugs in place....IE the tip of the drain plug is the same color as the inside of the pan. My oil drain plug is grey on the tip as a result...Others have experienced the same......I'd imagine the grey you saw was paint.
If you have no crushable copper gasket in place, the oil will seep, albeit slowly, from the threads of the plug.
SC~
Old Jul 18, 2003 | 09:38 AM
Sorry, I left that part off. The washer is still on the drain plug, but I did not replace it with a new one. Usually you can use them more than once, at least with my experience you can.
Shawn
Old Jul 18, 2003 | 09:40 AM
unless you torque the bolt down harder than you did initially, you are not further crushing the washer. If you aren't crushing the washer further, you are not assured an airtight seal.
For the cost, the 30 cents is worth the peace of mind to me...
SC~
Old Jul 18, 2003 | 09:41 AM
Yes I will be attending that event...
Shawn
Old Jul 18, 2003 | 09:43 AM
SC~
I completely agree, I just didn't have a new one with me at the time. Bu there was grey rtv around the lip of the bolt head. So they must of had the same seeping problem. I hope a new drain bolt and crush washer fixes things for me. I'll update you tomorrow.
Shawn
Old Jul 18, 2003 | 09:52 AM
wreckleford's Avatar
I'm just curious... why are you returning your car back to stock? I read about your ECU and clutch problems etc. but those problems shouldn't require you to revert everything back to stock.
Old Jul 18, 2003 | 09:59 AM
There's a lot more than just the clutch and ecu these days. I'm taking everything RMR did to my motor for legal reasons I dont really want to go into here. Everything they did to the car other than the suspension/brakes is sketch at best. I'll just leave it at that. BTW, new price on the turbo kit 3K shipped, includes the modified rmr downpipe as well as the lower tie bar. PM me, ONLY if you're serious, NO tire kickers.
TIA,
Shawn
