The Official 50k check in!!
Old Dec 12, 2007 | 08:01 PM
badboybr09's Avatar
Is that all? Ok thanks
Old Dec 12, 2007 | 08:12 PM
fugiwara's Avatar
All the problems, wear and tear you mention below don't really count, b/c you didn't own the car to begin with. therefore, problem w/ tranny, seats should last longer than 50k. My 05 MR has 42k miles and my car still looks, feels like new, your 03 evo has not been well taken care of, this post is not accurate for potential evo buyers.
[QUOTE=DSM GSR04;5045431]
DRIVETRAIN: (All Stock, except for ACT clutch)
Grinds when cold, 5th gear grinds, somewhat notchy, clutch chatters but does hold strong with no slippage, not sure of mileage on the clutch tho.
Transfercase is shot, whines through all gears all the time, although the interal and external seals have been replaced. Other than that nothing else to report.
INTERIOR:
Drivers seat shows some wear, im not a big guy so its holding up ok. The side bolster is broken and tends to click around if you lean on it just right. The center console suede is wearing, floor mats are wearing in typical spots. All dash lights are still bright, and my A/C knobs all function as they should. Stock HID bulbs are still bright and not burnt out.
OVERALL/ MISCELLANEOUS:
The car still feels great!! Plugs and timing belt will be done soon due to the mileage. All fluids have been replaced with stock fluids, including mobil 1 oil every 3 thousand miles. The car is lowered on GF210's with the stock struts/shocks, but they still seem to be ok ( no leaks, and not too bouncy). The sunroof is broken tho which sucks!!
This thread is for potential buyers of used/new evos just to have as a reference to how the 03's are holding up. Of course its not the highest mileage evo but I hope it helps comfort some people.
Old Dec 13, 2007 | 07:06 AM
KillaItalian904's Avatar
71,000 miles havent had any major problems because i replaced alot of things at 60k. Did timing belt balance shaft belt, water pump, clutch, all the tensioners and the accessory belt
Old Dec 13, 2007 | 07:43 AM
scheides's Avatar
EvoM Moderator
Originally Posted by DSM GSR04
^^^change all diff and tranny fluids, motor oil, plugs, timing belt and accesory belt. and brake pads and rotors if necessary.
And water pump, and all tensioners for these various belts.
My 05 evo has almost 50k on it and is holding up awesome! Had a clear-bra on it since day one so the paint is mostly perfect, replaced clutch at ~30k miles along with all the fluids. Car makes ~335whp on dyno dynamics, full br stage4 + alky and some other fun stuff, and I use all of it every day. Very reliable and just keeps me happy!
Old Dec 13, 2007 | 08:02 AM
1slowevo's Avatar
over 55k miles here. The car was basic with bolt ons making 400awhp/400tq till about 50k. Since I have installed bigger turbo with supporting mods for fuel. Made well over 500awhp.
I had to rebuild the tranny once. but that was for the 3rd gear syncro problem. I havent had any issues with motor at all. Seat bolster on drivers side is getting a little soft for getting in and out. Clutch was replaced for the higher hp obviously.
Besides that, no problems with the car's electronics, motor, or interior.
Old Dec 13, 2007 | 08:14 AM
dsevo's Avatar
79K and not a single problem . Car feels like the day I bought it. I don't know if I just got lucky, but it is an extremely tight car even after 80K miles.
Old Dec 13, 2007 | 08:16 AM
jamevo8's Avatar
funny.. my Ix turned 50k today also... It just had its 2nd birthday last saturday as well.
Still runs and looks like new!!!!
Old Dec 13, 2007 | 08:21 AM
MitsuJDM's Avatar
I bought it with 61k in June and I'm now at 68k in December.
When I bought it, all that was done was an MBC, and Tein S-Techs. I've done a TBE, cone filter, BOV, DIY catch cans, MR tails, Vortex Generator, and other misc. stuff.
As far as maintence goes: Trans, Tcase and rear differ fluids changed at 62k. I've replaced the timing belt, balance shaft belt and tensionor at 64k. Threw my first p0300 at 64k. Went home, changed the spark plugs gapped to .026, reset the ECU and no misfire/p0300 since then in the last 4k. I've changed the oil twice since I've had it, and put gas it it about 31 times
As far as the clutch goes, I have no idea. I bought the car used, and with the mileage the car has I'm going to make an assumtion and say it's NOT stock. But no slippage or any weakness so far. I'm going to leave it go until it starts slipping
Old Dec 13, 2007 | 01:00 PM
DSM GSR04's Avatar
[QUOTE=fugiwara;5050435]All the problems, wear and tear you mention below don't really count, b/c you didn't own the car to begin with. therefore, problem w/ tranny, seats should last longer than 50k. My 05 MR has 42k miles and my car still looks, feels like new, your 03 evo has not been well taken care of, this post is not accurate for potential evo buyers.
^^^how does it not count buddy? I am reporting the condition of the car after 50k miles, regardles of who owned the car, the condition is still the same. Its actually been well taken care of seeing as how there is not a single scratch on the vehicle and the only true problem is the T-case which is known to fail regardless of proper maintence. Stay out of my thread!
Your 05 MR is only 2 years old, mine is 4, so your car better still feel new or you have more problems then everyone in this thread combined!!
Old Dec 13, 2007 | 01:50 PM
Corey's Avatar
So what should I do with 8400 miles on it?
Old Dec 13, 2007 | 02:34 PM
emagdnim8's Avatar
drive it some more
Old Dec 13, 2007 | 08:11 PM
Kins's Avatar
Originally Posted by badboybr09
my tach just turned to 60k.... Can anyone tell me exactly everything I need to do for the 60k mile service i dont feel like searching and when I do i dont find what Im looking for.
I got this info from my login on Progressives website:
Routine Maintenance Guide
Routine Maintenance for mileage 60,000
Service items Parts Cost Labor Cost
Change Engine oil $11.25 $17.00
Inspect Drive axles $0.00 $8.50
Inspect Brake linings & rotors $0.00 $25.50
Inspect Suspension $0.00 $4.25
Replace Oil filter $6.20 $8.50
Rotate Wheels & tires $0.00 $25.50
Change Transfer case fluid $9.00 $42.50
Inspect Brake lines, hoses & connections $0.00 $1.70
Inspect Ball joints & steering linkage $0.00 $8.50
Replace Air filter $21.60 $3.40
Change Manual transmission fluid $6.00 $42.50
Change Differential fluid $6.00 $42.50
Flush/replace Coolant $8.00 $59.50
Inspect Fuel system $0.00 $8.50
Inspect Exhaust system $0.00 $4.25
Inspect Coolant, hoses & clamps $0.00 $12.75
Inspect Fuel lines, hoses & connections $0.00 $4.25
Replace Drive belt(s) $30.00 $34.00
Inspect Evaporative control system $0.00 $8.50
Replace Spark plug wires $53.60 $17.00
Replace Spark plugs $21.60 $42.50
Replace Radiator hose, lower $17.00 $59.50
Replace Radiator hose, upper $12.00 $42.50
Replace Heater hoses $35.00 $102.00
Replace Timing belt $101.60 $212.50
Subtotal: $338.85 $838.10
Estimated Total Cost $1,176.95
Routine Inspections
Calendar Frequency Action Parts and Cost
5 months Change Engine oil
5 months Inspect Drive axles
5 months Inspect Brake linings & rotors
5 months Inspect Suspension
5 months Replace Oil filter
5 months Rotate Wheels & tires
15 months Check level Transfer case fluid
15 months Inspect Brake lines, hoses & connections
15 months Inspect Ball joints & steering linkage
15 months Replace Air filter
15 months Check level Manual transmission fluid
30 months Change Manual transmission fluid
30 months Change Transfer case fluid
30 months Change Differential fluid
30 months Flush/replace Coolant
30 months Inspect Fuel system
30 months Inspect Exhaust system
30 months Inspect Coolant, hoses & clamps
30 months Inspect Fuel lines, hoses & connections
30 months Replace Drive belt(s)
60 months Inspect Evaporative control system
60 months Replace Spark plug wires
60 months Replace Spark plugs
60 months Replace Radiator hose, lower
60 months Replace Radiator hose, upper
60 months Replace Heater hoses
60 months Replace Timing belt
120 months Inspect Supplemental Restraint System
Estimated Total Labor Cost $889.10
I hope this helps. I thought it was pretty usful. I hope it can help others too
Old Dec 15, 2007 | 10:35 PM
badboybr09's Avatar
^^^it does indeed. good info, nice find.
Old Dec 15, 2007 | 11:50 PM
kilgoja's Avatar
20k+ and no problems....
i think a lot of these problems are caused by the way people drive the evo and the upgrades they do....example...launching, more hp and torque, etc.
that's what causes stuff to break like the clutch going out and t-case going out
especially at such an early mileage....take my advice...if u want ur evo to last then keep it stock...otherwise breakage is on the way...which means you have to spend more money to keep it running....if you got the money then no big deal...but i suggest if your gonna change stuff then change everything in the car
i guess i'm one of the few that will being leaving their evo stock....i mean if my clutch goes out at 50k i'm gonna fix it then trade it in....that's rediculous...i mean i can understand that if you're racing the car every weekend or something...but mine is just a dd so i better get more than that out of a clutch...i guess i've been spoiled by hondas, toyotas, and nissans ...hardly anything ever broke...if it did it was very minor and cheap to fix
Old Jan 8, 2008 | 08:21 PM
Wheatley's Avatar
68k plus. demo car for mitsu. I knew the orig owner from day one and I am the second to enjoy this car. Orig owner bought with 2k of VERY hard driving thanks to everyone that has ever wanted to test drive an evo. I love my car and has been very reliable for a car that has been driven with all intentions to enjoy it to the fullest I also am very **** about vehicle maintence and try to stay ahead of any problems that may occur. Typical problems, just replaced floor mats, need consol lid replaced and the seat is getting worn.
