EVO 9s ALL HAVE 2 STEP??
Old Dec 13, 2007 | 10:47 PM
RazorLab's Avatar
05+ have launch limiter at 5000rpm
03-03 have it set at 7969 which basically makes it not work. Drop it to your desired rpm via a tune and you are good to go.
Old Dec 14, 2007 | 10:26 AM
xl702Kinglx's Avatar
does any one have two step? if you do can you make a vid
Old Dec 14, 2007 | 10:34 AM
badboybr09's Avatar
both evo 8 and evo 9 have 2 steps, the thing is the RPM's on the 8's are set higher than the ones on the 9's.
Old Dec 14, 2007 | 10:42 AM
SlowSportSedan's Avatar
http://youtube.com/watch?v=ac6dI5gGPqk
The popping at the beginning is the 2set that run was set to 5800 i believe
Old Dec 14, 2007 | 11:18 AM
KillaItalian904's Avatar
get a tactrix cable and ecuflash... set ur stationary rev limit lower but they all have the ability built in thats what a 2step is....
Old Dec 14, 2007 | 11:34 AM
Mr. Evo IX's Avatar
All USDM Evo's have a stationary rev limiter or limited launch control, however as it's already been stated in a previous post the 03's stationary rev limiter is set above the normal rev limiter thereby making it non-functional.
Also, from the factory the IX's stationary rev limiter is set to 5000rpms, it's purpose is to protect the drivetrain components from shock damage due to the sticky tire compound on the car. Most people change this value to 6000rpms so that the car will spin the tires a little off the line instead of bogging.
Old Dec 14, 2007 | 11:59 AM
Rally R's Avatar
I heard that my IX had this as well. But I tried it the other day and the RMPs grew a lot higher than 5k before I let off. Is there a way to get this to work, could it have been removed with the previous owner did the re-flash?
I have however barely touched the limiter on the top end while running...
Old Dec 14, 2007 | 12:03 PM
SiCKlEyWiKeD's Avatar
If you bought it used then he might have unplugged it or raised it. The best way to find out is to pull up your ecu on a laptop using the tactrix cable.
Old Dec 14, 2007 | 01:46 PM
highbredcloud's Avatar
Originally Posted by beemerfreak
5,000 rev limiter.
Kunal tuned your car too...lol...naiiice...
Old Dec 14, 2007 | 04:38 PM
beemerfreak's Avatar
Yup, U?
Old Dec 14, 2007 | 04:46 PM
Yup, U?
Yeah...same here he did mine and my buddies VIII...what do you think? seemed right for the price...
Old Dec 14, 2007 | 05:32 PM
U can say that. I'm in need of a retune. I'm only tuned for 19 PSI
I got tuned before I installed my boost controller.
I know alot of cars he tuned what part of Chi are you from?
Old Dec 14, 2007 | 05:45 PM
o-townFLA's Avatar
You have to be at a "stand still" with the car in 1st and the clutch pushed all the way down as well as the gas... The most boost i could build was about 6-7psi... and feather the clutch out, dont just dump it....
Old Dec 14, 2007 | 05:46 PM
EvoJoeIX's Avatar
Originally Posted by SpeedJunkyz
LOL I mean the limiter is basically the launch control, well part of it anyways and having it set at around 5k is a good pop off stand point to build boost to launch.
SJ
your completely wrong....
theres 2 limiters on a IX
one is stationary, one is the normal 75?? RPM limiter
there are not the same thing
Old Dec 14, 2007 | 06:01 PM
E\/0IXG$R's Avatar
Here's what the stock launch limiter sounded like after I put on my TBEClick.
Non MR.
