Early Fuel Cut???
Old Dec 28, 2007 | 05:22 AM
philevo's Avatar
Early Fuel Cut???
I was getting on the highway this morning, I was in 4th going about 50, I noticed the highway was clear so I put the pedal to the floor. The car didnt pull at all and it hit fuel cut at about 6000 rpm!!! I shifted into 5th and the car felt like normal. I had no room to test it again but, what happened?
Old Dec 28, 2007 | 05:33 AM
WaxThis2005's Avatar
get it tuned,
Old Dec 28, 2007 | 05:37 AM
vboy425's Avatar
Originally Posted by WaxThis2005
get it tuned,
+10000
with all the mods he got, you would think he got it tune by now
Old Dec 28, 2007 | 05:44 AM
rcheung's Avatar
Originally Posted by vboy425
+10000
He definately didn't mention wether he got a tune or not but he would be foolish if he hadn't and wondered why it felt like he hit a brick wall when he got on it. If it isn't tuned or you got a bad tune, take it to a reputable tuner. There are a couple in jersey who do great jobs.
Old Dec 28, 2007 | 05:46 AM
vboy425's Avatar
i don't think he have, unless the tuner didn't flash to have hte boost cut remove.
Old Dec 28, 2007 | 06:27 AM
philevo's Avatar
No tune yet... I had the car for about 5 months now and i was waiting to get cams and my friend to get his dyno put in to get a tune. This is the first time the car acted like this.
Old Dec 28, 2007 | 06:30 AM
rcheung's Avatar
It doesn't always do it. Temperature and conditions have alot to do with it too. I had the same problem with similar mods to yours when I was untuned and it didn't happen until 6 months later but I did finally got a tune and it never happened again.
Old Dec 28, 2007 | 06:31 AM
K1lla Haz3's Avatar
def get it tuned
Old Dec 28, 2007 | 06:37 AM
kaonashi's Avatar
probably because it was pulling timing and running rich and your maxing out the fuelpump, def get a tune. shouldnt be hitting fuelcut with the 255
Old Dec 28, 2007 | 06:39 AM
K1lla Haz3's Avatar
+1 fuel pump...
Old Dec 28, 2007 | 07:03 AM
ninja7's Avatar
fuel
strangely the same thing happened to me when the weather changed. I do have a flash, but I think it was tuned at around 25psi. I am not comfortable with that much on pump so I tured the boost down to around 22psi. Needless to say its running rich. In addition, since it was so cold coupled with the tune not right, I hit fuel cut at around 5k in 4th gear.
Old Dec 28, 2007 | 07:09 AM
Evo8's Avatar
And trust me this is not the last time it acted like this, unless you do get it tuned. That's it, closed thread
Old Dec 28, 2007 | 03:59 PM
vboy425's Avatar
with MBC higher gear higher spike, higher load higher spike, cold weather higher spike. All you have to do is to put the Boost cut all columns to 319
Old Dec 28, 2007 | 05:47 PM
filter's Avatar
how do you have those mods and no tune.
isnake
Apr 9, 2017 02:01 AM
Sir_Lancer_Lots
Lancer Troubleshooting
Nov 7, 2016 09:47 PM
Evo_Jr
44
Feb 3, 2011 09:04 PM
dragon831
Jul 24, 2009 07:09 PM
BlackTypeS
12
Apr 12, 2007 06:16 PM
