Dropin or short ram?
Old Dec 29, 2007 | 04:36 PM
Canexican's Avatar
I say: no airbox, no filter, no pipe, no mas...i mean honestly, who needs all that restriction anyway!?
Old Dec 29, 2007 | 10:56 PM
gixxer6's Avatar
Just because there are old threads with the same topic doesnt mean there arent new opinions and products, therefore even if you searched posting this thread is fine with me. Back to the topic though, i say if you can afford it get the short ram n a slight tune
Old Dec 30, 2007 | 02:06 AM
krazirob's Avatar
^^^^well put
Old Dec 30, 2007 | 04:38 AM
PHDoc19's Avatar
Originally Posted by Mr. Evol
Works has a drop in that looks nice but cobb tuning i know has a good rep and for the same price I could get their short ram that says does mess things up like other short rams. What do you guys think?
Well it depends on what your next mod/mods are gonna be...
Old Dec 30, 2007 | 08:02 AM
Mr. Evol's Avatar
The main reason I ask is because I only intend to mod Lightly(TBE, cobb ap)
Cobb says the short ram works with their stage 1 and 2. Everyone seems to say a short ram is good but you need to tune for it. I assume the ap takes care of the tuning end of it. thanks for your replies so far.
Old Dec 30, 2007 | 08:13 AM
Robevo RS's Avatar
theoraticly you need to tune after any changes . Example exhaust intake etc.
But it is better off like you planning to do it . change everything once and get the tune.
I would say if you short of money, then dropp in will work fine with basic bolt ons.
But for me, or for the future reference /since the hp and tq is addictive/ get the short ram. And i would say get a good one so you don't need to change it. I tryed many of them so learn my mistakes and get the HKS RS, with different cone.
Old Dec 30, 2007 | 09:02 AM
destro92179's Avatar
i would get a drop in filter and drill some holes on the bottom of the air box.....works wonders
Old Dec 30, 2007 | 09:40 AM
90GSX-03EVO's Avatar
Indeed. Since heat rises, the colder air is found under the air box. The difference in atmospheric pressure that you create when doing this will also help spool-up time since fluid dynamics will ensure that the air follows the path of least resistance and utilizing the venturi effect you will actually gain both HP and TQ on the low end. You'll only gain HP up top though as this will probably because a bit of a restriction at higher velocities as the air becomes more turbulent as it collides before hitting the MAS.
Old Dec 30, 2007 | 09:50 AM
BluEVOIX's Avatar
Drop in filter rests at the top of the air box. If you drill holes at the bottom of the air box, how do you expect any filtration to occur from there? You'd be sucking in dust and dirt from the bottom of the box.
Oh and regarding cone intakes. I had the AMS cone filter setup previously and compared to the stock intake, I was holding .1 - .2 bars more nearing redline. (only other mod is a cat-back exhaust)
Old Dec 30, 2007 | 12:44 PM
*cough* he was joking *cough*
Old Dec 30, 2007 | 01:24 PM
BluEVOIX's Avatar
Ooops, he got me there lol
Old Dec 30, 2007 | 01:29 PM
gixxerman11's Avatar
short ram with tune
