If a UICP blows...
Old Jan 4, 2008 | 06:43 AM
kingman4's Avatar
Originally Posted by pure_evo
I can only sympathize with you when I say that it happened to me yesterday for the first time. I put on my Injen UICP/intake set and had one of my buddies rev the engine so that I can see if I could "hear" if something was leaking (as if I'm a scientist or something). He's not an Import fellah and just when he was getting his rocks off from listening to the intake, he said, "It sounds pretty good". Then... BAM! The hose on the throttle body blows off and I was like . "Turn it off! Turn it off! Before I read this thread, my paranoia was getting the best of me not knowing if I was even safe to drive my car until I got some clarification. I'm glad that I now have it!
haha be glad you weren't going 80 on the highway when it happed :P
also i think its worth getting an IC pressure tester to make sure everything's a-ok
http://vfaq.com/mods/ICtester.html
Old Jan 4, 2008 | 07:50 AM
Levar's Avatar
Veteran: Army
Yeah. I am too! My mouth dropped and all I could picture was my hampster pulling a muscle trying to stop his little cage from spinning while screaming, "DANG!"
I'm going to pick up one of those testers you recommended.
By the way, I had all kinds of issues installing the driver's side LICP because it kept slipping out. I had to make a few small incisions in the rubber coupling to get it to finally slide it. I have to be honest with you, I don't want the same thing to happen that did with the throttle body clamp/coupling coming off. Should I be concerned with this considering how far down the intake stream it is?
Old Jan 4, 2008 | 07:57 AM
CrackerJackToy's Avatar
Imagine this... doing a 3rd gear WOT pull and at 7500 rpm it pops off for the first time... I thought I blew the engine but was praying it was an intercooler pipe! It was the one at the throttle body thank God.
Old Jan 4, 2008 | 08:12 AM
Levar's Avatar
Veteran: Army
OK. So correct me if I'm wrong:
#1 - throttle body coupling comes off at WOT...not so bad
#2 - intercooler pipe comes off at WOT...not so bad
#3 - intercooler pipe comes off at WOT...BAD
Old Jan 4, 2008 | 08:19 AM
subydudesti's Avatar
Nah man you are fine, it just runs rich as f*ck until you clamp it back down. Just dont get into any boost.
Old Jan 4, 2008 | 08:34 AM
Levar's Avatar
Veteran: Army
Thanks for the piece of mind!
Old Jan 4, 2008 | 08:37 AM
SlowSportSedan's Avatar
if it ever pops off and you dont have the tools handy... unplug ur maf and just stay out of boost and you can drive home or a place to buy a couple wrenchs...
Old Jan 4, 2008 | 09:06 AM
wingless's Avatar
I can barely get the thing to move at all with a hose blown off.
T-bolt clamps crush the aluminum pipes on my car so I have been buying a wiggens ($$!!!) clamp at a time every couple months until I have enough to fab a complete set of pipes w/o any conectors or clamps. Should be done in a year or so at this rate. Overkill I know, but it makes me happy
Old Jan 4, 2008 | 10:35 AM
Levar's Avatar
Veteran: Army
Slow... , thanks for the nugget.
Is there anyone else having issues with the T-bolt clamps crushing the aluminum pipes?
Old Jan 4, 2008 | 11:54 AM
JspecEfini's Avatar
haha! that happened to me a long time ago when i first got my car. drove it to the nearest gas station and popped it right back in with a friend. i didnt do any of the ic testing or change my plugs. it was normal after i popped it back in.
Old Jan 4, 2008 | 03:14 PM
redteam22003's Avatar
Originally Posted by TeStUdO
+1
Try Here for every clamp you need.
nice...I paid 7.99 for 3 of my T......thanks for the link
Old Jan 4, 2008 | 03:18 PM
just get the correct size and you dotn have to worry it... they dotn crush as easy as you would think
Old Jan 5, 2008 | 07:47 AM
Levar's Avatar
Veteran: Army
Thanks for the piece of mind.
